Go to Post FRC is about giving students the best experience possible. - MikeE [more]
Unread 08-03-2010, 13:01
charrisTTI charrisTTI is offline
Ramblin' Wreck
AKA: Charles Harris
FRC #0623
charrisTTI has a spectacular aura aboutcharrisTTI has a spectacular aura about
Send a message via AIM to charrisTTI
Re: Classmate Static Discharge Susceptibility
Originally Posted by Mark McLeod View Post
Similar symptoms I saw this weekend were tracable to under-powered USB devices. All Comms are good, but the robot doesn't respond to the driver controls.
These are the USB mistakes I saw teams making:
  • If you are using the PSOC it is usually the biggest power-hog. That must be plugged directly into the Classmate.
  • The USB hub should be plugged into the other Classmate USB connector and the joysticks into that.
  • If you have a real power-hungry game controller - lights/vibrate/etc. - that needs to be plugged directly into the Classmate too. So you may have to choose between the PSOC and any fancy game controller.
  • The Stop switch they gave us in the KOP is NOT used at competition. Unplug the power drain to run those color changing LEDs.
The National Instruments rep at DC said to be sure to plug the RED power only USB cable into one of the classmate ports and the BLACK USB cable into the remaining port. We then had one KOP joystick, one Logitech Extreme 3D Pro, and the Cypress module plugged into the hub. Stop button stayed in the pit area. Still saw problems with this configuration.
FRC 623 2003,2004,2005,2006,2007,2008, 2009, 2010, 2011
FRC 1900 2007
FVC 60 and 193 2006
FVC 3271 2007
FTC 226 and 369 2008, 2009, 2010, 2011
FTC 3806 2010
Electrostatic Discharge rsegrest Electrical 6 18-02-2010 23:24
Static Buildup Rafael Vasquez Electrical 6 15-02-2010 23:51
When a Robot Does Rounds Patients Get Faster Discharge JohnBoucher Math and Science 0 16-07-2007 08:03
Battery Life, 50A load discharge test method/results Dale(294engr] Electrical 5 22-01-2006 09:14
Static Electricity archiver 2001 12 24-06-2002 00:34
