Go to Post I would go even further and say always hate your robot. Keep breaking, iterating, and trying to figure out how to change the robot from week one of build season to champs. - saikiranra [more]
Unread 07-03-2010, 19:39
Patrick Chiang Patrick Chiang is offline
Programming
FRC #3070 (Team Pronto)
Patrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to all
On mecanum wheels
Would purchased mecanum wheels work as well if placed in a rectangle instead of a square like they're supposed to?
Unread 07-03-2010, 19:40
Stephen of REX's Avatar
Stephen of REX Stephen of REX is offline
FRC #1727 (REX)
Stephen of REX is an unknown quantity at this point
Re: On mecanum wheels
I've never heard of them having to be in a square. A rectangle should be fine!
Go REX!!!
Unread 07-03-2010, 19:42
alicen's Avatar
alicen alicen is offline
Zebra Committee
alicen is just really nicealicen is just really nicealicen is just really nicealicen is just really nicealicen is just really nice
omnis are the ones generally put in a square pattern
mechanums work perfectly fine in a rectangle
Unread 07-03-2010, 19:43
Programming
I don't know. I'm assuming that the rollers have to point to the center of the robot, and if they're oriented at a 45 degree angle, so they would have to be in a square. But we've never tried, so we don't know for sure. None of the reports we've read seemed to indicate that this is the case, but many of our team members were pretty certain.
Thanks for the replies. Good to know.
Unread 07-03-2010, 19:46
Hastypickle's Avatar
Hastypickle Hastypickle is offline
AKA: Nicholas
FRC #1703 (Rats)
Hastypickle is an unknown quantity at this point
Mecanum wheels work when in a rectangular configuration, although I can see how some people may think they must be in a square if they are told that the wheels must be in an x configuration when viewed from the top.
Unread 07-03-2010, 20:09
Ed Sparks Ed Sparks is offline
Engineer/Mentor/Inspector
AKA: FirstCadLibrary Guy, Inspector Dude
FRC #3959 (Formally with FRC-34)
Ed Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond repute
Send a message via AIM to Ed Sparks Send a message via Yahoo to Ed Sparks
We're living proof. We're running in a recangular configuration with absolutely no issue.
Ed Sparks
MECH TECH FRC-3959
Unread 07-03-2010, 23:06
Holonomic drivebases really work best if the rollers touching the ground are all directed right at the same point (usually the center of the robot). With 45-degree mecanum rollers, that does mean a square is optimum. But a rectangle still works fine, with only a tiny bit of power lost due to scrubbing friction.
Unread 08-03-2010, 10:01
Chris is me's Avatar
AKA: Pinecone
Omnis don't even "need" a square either, though they can be really annoying in a rectangle.
Unread 08-03-2010, 13:38
Just to be clear, for those unfamiliar:
"Holonomic drivebases really work best if the perpendicular bisectors of the axles of the rollers touching the ground are all directed right at the same point"
Unread 08-03-2010, 14:02
TheDominis TheDominis is offline
FRC #2152
TheDominis has a spectacular aura aboutTheDominis has a spectacular aura about
Our robot is using mecanums in a rectangular configuration. It works very well.
mecanum wheels. gabi0407 Technical Discussion 12 16-02-2010 19:28
Mecanum Wheels? Maxpower57 Kit & Additional Hardware 17 17-03-2008 16:50
Friction coefficients for Omni wheels and Mecanum wheels from AndyMark Andy Baker Technical Discussion 11 16-12-2006 19:40
Mecanum Wheels chaolin2007 Control System 1 25-02-2006 19:16
Mecanum Wheels TheFerret Technical Discussion 8 16-01-2006 09:23
