Go to Post Sometimes you have to eat your vegetables, do your homework, and get some sleep. Otherwise you may get sick, have bad grades, and or fall asleep during the championship. - IKE [more]
  #31   Spotlight this post!
Unread 08-03-2010, 14:07
TheDominis TheDominis is offline
FRC #2152
TheDominis has a spectacular aura aboutTheDominis has a spectacular aura about
Re: Simple Custom Video Dashboard 30+ FPS
Sure...
It'll take me about 30 minutes or less...
or maybe longer... not much though
  #32   Spotlight this post!
Unread 08-03-2010, 14:16
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Robototes2412 is on a distinguished road
thanks
  #33   Spotlight this post!
Unread 08-03-2010, 16:02
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Originally Posted by Robototes2412 View Post
thanks
my ZomB .net 2 port *SHOULD* be mono AND wine friendly (have not tested however)
http://www.chiefdelphi.com/forums/sh...ad.php?t=82612
EDIT: Mono migration tool says one error, but it is easily fixed, I'll post a mono-friendly version in about 3 minutes. void Receiver_OnImageUpdate () Image Image.FromStream (Stream, bool, bool) useEmbeddedColorManagement and validateImageData aren't supported.
EDIT2: posted at above url
Watchdog.Kill();
  #34   Spotlight this post!
Unread 08-03-2010, 16:17
FRC #2152
I have ported the video dashboard to 2.0 .NET as well as made it (most likely) Wine friendly. I also made the program more robust -- probably.
Please report any issues.
  #35   Spotlight this post!
Unread 10-03-2010, 12:50
buchanan buchanan is offline
FRC #2077 (Laser Robotics)
buchanan is just really nicebuchanan is just really nicebuchanan is just really nicebuchanan is just really nice
I read with some surprise the following thread:
http://www.chiefdelphi.com/forums/sh...ad.php?t=84087
I'll ask here: for the developers and users of this video dashboard, what networking setup are you using between the classmate and the machine displaying the video? Is it known to work under a real FMS?
  #36   Spotlight this post!
Unread 10-03-2010, 14:13
FRC #2152
The classmate displays my video. I get 30+ FPS.
  #37   Spotlight this post!
Unread 10-03-2010, 14:49
hamosad1657 hamosad1657 is offline
FRC #1657
hamosad1657 is an unknown quantity at this point
How you get the screen on the "Driver" Account?
I opened it on the "Developer" account, and I got 5fps....
  #38   Spotlight this post!
Unread 10-03-2010, 14:55
FRC #2152
Are you running the right executable on the developer account? If so, 5 fps makes no sense as we all have the same computer...
  #39   Spotlight this post!
Unread 10-03-2010, 14:59
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
What resolution are you getting the 30FPS at? That may be one possible difference between your setup and theirs.
EDIT: Also how tough would it be to implement command line parameters for robot IP, and starting size and location of the window? I am looking at calling this from a Labview dashboard and while we could position it and enter the IP every time that seems a bit cumbersome. I would try it myself if I knew C#...
  #40   Spotlight this post!
Unread 10-03-2010, 20:42
FRC #2152
I can make it take an IP from a file. I'll have a new binary posted in a few minutes.
Just create a file called smash-ip.txt in the start up directory and the first line will be the IP.
  #41   Spotlight this post!
Unread 11-03-2010, 07:27
FRC #1657
I have an Edimax router, maby it impressive the communication?
And how can I get it running on the Driver account?
  #42   Spotlight this post!
Unread 11-03-2010, 08:59
FRC #2152
You'll have to set it as a start up program with Windows. As far as the router, I wouldn't have any idea.
All I can report is that I get 30+ FPS on our team's classmate. Perhaps you can change power saving options so that they are on performance.
  #43   Spotlight this post!
Unread 11-03-2010, 21:27
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
What settings are you running on the crio? 320x240? Any compression?
Thank your for making this, the LV dashboard kills the poor classmate cpu.
  #44   Spotlight this post!
Unread 11-03-2010, 21:52
For those getting mysteriously low frame rates one thing to check is the camera configuration. The Axis camera's video server has an option to limit the frame rate, and there may be (or have been) software floating around that reconfigures it without your direct intent..
Connect the camera directly to a computer that's configured with a 192.168.0.X IP address, and open the camera IP (192.168.0.90) in a web browser. Go to the video configuration page and see if the frame rate limiting is set.
This happened to us. When we first tried the camera, running direct to a web browser, it was real-time video fast. Later in the build season, running through the cRIO/classmate/video dashboard we were stuck at 2 FPS no matter what we did. Looking at the config page, guess what we found? We have no idea how it got that way.
  #45   Spotlight this post!
Unread 12-03-2010, 07:15
FRC #2152
I use only the following code :
AxisCamera &camera = AxisCamera::GetInstance();
camera.WriteResolution(AxisCameraParams::kResolution_320x240);
camera.WriteBrightness(50);
As you can tell I used 320x240 at default compression (0 - I believe).
How to set up custom dashboard for auto start Kevka Programming 11 28-01-2010 18:46
Custom Dashboard writchie FRC Control System 7 02-03-2009 20:21
Custom Dashboard - Visual Basic Mike Lat Programming 3 23-01-2005 14:26
Custom Dashboard Executable ready for Download! archiver 2001 1 24-06-2002 01:01
Custom dashboard program available. Interest? archiver 2001 4 24-06-2002 00:45
