Go to Post We draw the line when our students are more affectionate towards the tools rather than eachother. - ksafin [more]
Unread 21-02-2010, 02:51
roknjohn roknjohn is offline
roknjohn is an unknown quantity at this point
Tank Drive is backwards
Ok, I have a strange issue that makes me think that my joysticks Y axies are 'inverted'. Here's the deal, I'm driving with code like this:
m_robotDrive->TankDrive(LeftJoystick, RightJoystick);
I know that my left and right joysticks are defined correctly because the buttons of each control the desired actions. However, the drive train output isn't correct.
When I press forward on the left joystick, the left hand jaguar leds turn RED and the left motors run backwards. Similarly, when I move the right joystick forward, the right side motors run backwards and the leds are again RED. Moving the joysticks backward, cause the respective motors to run forward and the jaguar LEDs turn GREEN.
Now, obviously I could rewire the motors to get the robot to travel in the correct direction. But shouldn't the LEDs be GREEN for FORWARD and RED for REVERSE?
Unread 21-02-2010, 08:39
Re: Tank Drive is backwards
The Y axis value for a standard joystick is indeed "inverted" from what most non-pilots would expect. Forward is negative.
Unread 21-02-2010, 09:20
whatabouteve whatabouteve is offline
AKA: Dean Keithly
FRC #0245 (Adambots)
whatabouteve is an unknown quantity at this point
the colors mean nothing. it basically means the flow of electricity.
you shouldn't judge the movement of the robot by the colors.
i would change the power to the motors that way when u run autonomous, you have code like...
myRobot.Drive(1.0,1.0);//for forward
instead of
myRobot.Drive(1.0,-1.0);// for forward
this makes it easier from a coding standpoint
Unread 21-02-2010, 09:33
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
instead of
you are using Drive, not TankDrive, that example is doing donuts at full speed! I think you meant
myRobot.TankDrive(1.0,1.0);//for forward
instead of
myRobot.TankDrive(-1.0,-1.0);// for forward
Watchdog.Kill();
Unread 21-02-2010, 09:47
Actually, I am a pilot (instrument rated, too). Now as soon as we get our robot flying, the controls would make sense.
But obivously, we want our drivers to push the stick (yoke) forward to drive the robot forward. So, full forward on the stick is -1.0 on the Y-axis? OK, then robotDrive.SetLeftRightMotorSpeeds(-1.0, -1.0) is supposed to drive the robot forward?
It just seems counter intuitive to me, but I've recently rejoined the team after a two year absence - so my thinking may be a bit "old school".
Unread 21-02-2010, 09:54
instead of
If memory serves me correctly, on the spikes and victors, the LEDs glowed green for normal polarity and red for reversed polarity. As such, we've always wired our motors and control logic to match. It just made things simpler to troubleshoot, code, etc.
So, please correct me if I'm wrong.. If we used the RobotDrive class, we have to think of "forward" as the "negative" direction? Sounds just like the economony?
Unread 21-02-2010, 10:29
I think I'm going to try something like this later today:
myRobot.SetInvertedMotor(myRobot.kFrontLeftMotor, true);
myRobot.SetInvertedMotor(myRobot.kRearLeftMotor, true);
myRobot.SetInvertedMotor(myRobot.kFrontRightMotor, true);
myRobot.SetInvertedMotor(myRobot.kRearRightMotor, true);
Unread 24-02-2010, 17:52
pafwl pafwl is offline
Franciose
AKA: Frank Larkin
FRC #0272 (Cyber Crusaders)
pafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud of
The invert is the answer. Forget about the colors. If you add 1 gear the direction is reversed. Add 2 reversed again.
The Joystick is -1 for full forward. It does not make sense except at a binary level reverse has (-1) more bits on than forward.
Unread 24-02-2010, 20:29
AKA: Dean Keithly
here is exactly what i did.
Joystick leftstick;
Joystick rightstick;
Victor *left;
Victor *right;
left = new Victor(4,1);
right = new Victor(4,2);
float leftdrive = leftstick.Get();//do the same with the right and you can change the joystick values to make say halfspeed by dividing by 2
left->Set(leftdrive);
Unread 25-02-2010, 00:14
nathanww nathanww is offline
Hacker
FRC #1678 (Citrus Circuits)
nathanww is just really nicenathanww is just really nicenathanww is just really nicenathanww is just really nice
You can do it either by telling RobotDrive to "invert" the motors, or using whatabouteve's example. I personally prefer the latter because it allows your program to very easily hook into your drive code(i.e.you don't have to re-do your ramping system for when the robot is running on camera tracking)
Get yer robot source code here!
Unread 27-02-2010, 23:13
Al3+'s Avatar
Al3+ Al3+ is offline
ARTist
AKA: Anthony
FRC #0840 (Aragon Robotics Team)
Al3+ is a jewel in the roughAl3+ is a jewel in the roughAl3+ is a jewel in the rough
Couldn't you also do the following:
drive = new RobotDrive(1, 2);
float leftSpeed = -leftStick.Get();
float rightSpeed = -rightStick.Get();
drive->TankDrive(leftSpeed, rightSpeed);
That's similar to what I've done at the moment. It's not as "proper" as SetInvertedMotor, but it appears to work.
cout << "Hello, robotics. Goodbye, world." << endl;
"The two-axis accelerometer provided in the kit of parts (shown in the picture below) is a two-axis accelerometer." - WPILib User's Guide
Unread 27-02-2010, 23:17
jblay's Avatar
jblay jblay is offline
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
I would just go with taking the joysticks and flipping them backwards
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
Unread 01-03-2010, 23:10
cmh0114 cmh0114 is offline
AKA: Cam H
FRC #0217 (Thunderchickens)
cmh0114 will become famous soon enoughcmh0114 will become famous soon enough
You could always reverse the wiring on your bot so that it matches up with the joysticks. That would probably be the easiest solution and the best if you're really short on time. But if you have time before your next competition and can edit your code, multiply the values of the y-axis of the joysticks by -1 whenever you input them. That should fix your problem without adding too much extra code.
Thank you to teams 174, 188, 191, 610, and 1551 for some great matches in the FLR finals!!
Unread 08-03-2010, 01:10
Fletch1373's Avatar
Fletch1373 Fletch1373 is offline
AKA: Fletch
FRC #3181 (Panthers)
Fletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud of
I believe that the Jaguars' LED doesn't turn green... but anyone feel free to correct me
Student:
<04: FRC0213> <05-08: FRC1373>
Mentor:
<09-10: FRC0809> <11-12: FRC3555> <12-14: FRC0073> <15-??: FRC3181>
Volunteer:
<FTAA> <CSA> <Defense Coordinator> <Scorekeeper> <Robot Inspector> <Official Scorer>
2016 Tour:
CTWAT [DefCoord] > Pittsburgh[Mentor/DefCoord] > TVR[FTAA] > FLR[CSA] > NE DCMP[CSA] > CMP[CSA]
Unread 08-03-2010, 14:22
Alexa Stott's Avatar
Alexa Stott Alexa Stott is offline
All I do is twin.
AKA: elixir
FRC #0025 (Raider Robotix)
Alexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond repute
Send a message via AIM to Alexa Stott
Yup. Just reversing the wires on your bot will solve this problem quickly. Just remember that in case you need to change a motor or speed controller out.
|Email:alexastott[at]gmail.com|Facebook|@zelixir|Google+|
[University of Maryland Computer Science, Psychology]
[Brunswick Eruption]
Tank Drive 'sensitivity' fishLlama NI LabVIEW 5 19-02-2010 21:44
Tank Drive vs. Omni Directional Drive jamie_1930 General Forum 9 24-01-2010 22:50
Tank Drive Sauce Programming 1 05-01-2009 18:50
Tank Drive Idaman323 Programming 14 15-02-2005 09:01
tank drive Stormhammer Programming 11 29-01-2004 23:08
