Go to Post You know you are addicted to FIRST when you have trouble describing it because you realize it truly is way more than just a robotics competetion. - vivek16 [more]
Unread 08-03-2010, 15:34
Johnny's Avatar
Johnny Johnny is offline
We do it for the pizza
FRC #1266 (The Devil Duckies)
Johnny has a spectacular aura aboutJohnny has a spectacular aura aboutJohnny has a spectacular aura about
Re: FP ok to stall?
The only way to effectively use fisher price motors and not product magical white smoke is to have enough gear reduction built into the system so it doesn' stall. If you manage to do that, then the motors will produce magic in the form of winning matches otherwise, there is no real solution to the problem your team is having. The window motors or cimz would be better suited for the solution you previously mentioned
FRC http://www.frc1266.com/
Battlebots http://www.mutantrobots.com/
Toughbox stall torque Galum Motors 4 04-02-2010 15:47
motor stall current vs Victor ratings dawilliams Electrical 30 03-01-2007 08:29
Made to stall srjjs Motors 5 17-01-2003 19:00
What happens / why do motors stall? DanL Technical Discussion 19 21-11-2002 07:19
So you want to stall a Globe Motor... archiver 2000 1 24-06-2002 00:09
