Go to Post The worst that happens is we try our best and lose. And there's no shame in that. - pfreivald [more]
Unread 08-03-2010, 15:42
Rizner's Avatar
Rizner Rizner is offline
FRC #2425
Rizner has a spectacular aura aboutRizner has a spectacular aura about
Did anyone go for the Platform?
Hello,
I was wondering -- did any teams build a robot that would elevate by getting on top of the platform? My team had considered it but couldn't figure out a way to do this, and I was wondering if any others did.
Thanks.
Unread 08-03-2010, 15:47
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Re: Did anyone go for the Platform?
No one at GSR attempted too.
1058 PVC Pirates 2016 - xxxx
293spike 293spike is offline
293spike has a spectacular aura about293spike has a spectacular aura about
219 did. It was very neat actually. They had two arms that grabbed on to the side off the tower, and then they had an airbag that they would inflate. the arms rested them on the platform with the airbag still inflated, and when they deflated they would be on the platform, completely upside-down
Unread 08-03-2010, 15:53
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
I'm not sure I understand how this works...but it sounds really cool. Any videos?
Unread 08-03-2010, 15:58
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
I saw a robot (I think it was on the webcast, but don't know which one) which had a 2007-style ramp that another team could drive up onto the upper platform. Unfortunately, their partner that match had slick wheels and couldn't drive on their metal ramp.
Unread 08-03-2010, 16:38
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
Our robot drives from the bump to the platform
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 08-03-2010, 17:09
Rizner's Avatar
FRC #2425
interesting... do you know what matches or even regional they played in? Or even if there's any videos you know of...
May I ask how? Do you have larger or raised wheels in the front made to catch the platform?
Unread 08-03-2010, 17:17
gorrilla's Avatar
AKA: adam spears
no, we have two pneumatic cylinders that raise the front and the back.
we drive up the bump, turn sideways and get the the edge, deploy the front lifter, drive forward until the center wheels are on the edge, retract the front cylinder, fire the back and drive forward until the back wheels are on the platform then retract the back.
Adam Spears
Unread 08-03-2010, 17:24
Rizner's Avatar
FRC #2425
Very interesting. Are the cylinders attached to wheels or something that lets them slide when you drive and they're deployed?
Unread 08-03-2010, 17:29
gorrilla's Avatar
AKA: adam spears
they have a 3/8' bearing bolted to each shaft.
we've found its quite difficult to do, but I can come at the bump at an angle and kind of Dukes-of-Hazard the front wheels onto the platform and make it a lot easier.
Adam Spears
Unread 08-03-2010, 20:38
DonRotolo's Avatar
Back to humble
FRC #0832
219 competed at the NJ Regional. It was webcast, but I have no idea if anyone recorded it. I sure hope someone did, I'd like to see some of those matches over again...
Unread 09-03-2010, 01:25
Rizner's Avatar
FRC #2425
ok, thank you. I'll be sure to look into it.
thank you very much for the explanation.
Unread 09-03-2010, 08:32
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
1111 the PowerHawks had a ramp that could be deployed. I only saw one team attempt to use the ramp; it was misaligned and fell off the side. Anybody else watching the DC regional - was this ever successful?
Hi!
Unread 09-03-2010, 09:00
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
I was at NJ, heard about it, but did not see it in operation. However we abandoned such ideas for lifting and setting a hanging device, based on Q&A responses such as this:
http://forums.usfirst.org/showthread.php?t=13703
Unread 09-03-2010, 09:06
Hadi379's Avatar
Hadi379 Hadi379 is offline
FRC #0379
Hadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to behold
Team 379 will have a ramp at the Cleveland regional. We're hoping to be able to score 4 points in the finale. We will assist one team onto the platform, and then elevate another team above the platform as they make contact with the tower. Does this seem feasible compared to what was seen this weekend? With not alot of teams hanging so far this year, I think this may be a valuable option. Good Luck everyone!
Did anyone use all 4 CIM motors for the wheels tennisbeast29 Electrical 30 06-02-2009 22:07
Programs for the new FRC platform frcchile Programming 20 01-01-2009 14:29
2006: Did anyone use the Mabuchi motor? Billfred Motors 18 28-04-2006 21:44
Is Anyone Using Motors to Hoist themselves off the platform on the bar? xxlshortys Motors 36 25-02-2004 01:06
Did anyone see the Today Show? archiver 2001 1 23-06-2002 22:43
