Go to Post Time to iterate, more. - jwfoss [more]
Unread 08-03-2010, 16:01
Bandgeek80001 Bandgeek80001 is offline
FRC #2867
Bandgeek80001 is an unknown quantity at this point
Re: Week one regional control system showstoppers
Originally Posted by sparrowkc View Post
Second problem
During some matches, our joystick simply did not work. Inputs on the IO board did work, and the joystick was listed in the setup tab of the DS. I know of at least one other team that had this problem. I remember it happening on and off the field. It seemed to persist across power cycles and then fix itself. Ours was a logitech 3-axis joystick. It was going through the hub, and I couldn't reproduce it after I connected it straight to the classmate.
In the pre-season, we've figured out an annoying, yet seemingly foolproof way to fix the joystick thing in a pinch.
If you go into the DS, under the setup tab, you can see all the joysticks that the computer detects. If you reorder the malfunctioning one to a different position, and then move it back, this seems to fix the problem.
Ultimately I wish we knew a better fix, but this has worked in the several times we've experienced this problem.
And our Targus hub went out, too. We're planning to bring a few spares
BattleCry in Just ONE WEEK! WernerNYK Off-Season Events 43 02-07-2006 20:52
One More Week!!! Silent_Stryker Championship Event 27 17-04-2005 10:03
..one week... archiver 2000 2 23-06-2002 23:10
Control system with one joystick(or two) CharlieWilken Technical Discussion 3 04-02-2002 09:20
Week one OVER! Summmergrl2298 General Forum 15 14-01-2002 21:50
