Go to Post GP is a code which is lived by, not a yardstick to measure others by. - Daniel_LaFleur [more]
Unread 03-03-2010, 16:11
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
842's Ball Sucker
Its looks like we are giving up on the rollers. There are too many variables that we can't control. So we tried a vacuum system. This is on our twin Oscar.
http://www.youtube.com/watch?v=Xmmq1_JuQo0
Faridodin "Fredi" Lajvardi KD7WKD
Unread 03-03-2010, 16:23
nikeairmancurry's Avatar
nikeairmancurry nikeairmancurry is offline
FF - TeamSuperPowerMatic
AKA: Nicholas
FRC #0313
nikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond repute
Re: 842's Ball Sucker
If you don't mind answering what was the problem your team was occurring? Just curious..
On anther note, your vacuum system looks very efficient. Glad to see something different.
Team Member- 326 2006-2009
Team Mentor- 326 2010-2013
Team Mentor- 313/5220 2014-??
Unread 03-03-2010, 16:49
AKA: Ledge
surface stickiness of the rollers and the ball, changes all the time.....
Unread 03-03-2010, 16:57
AKA: Nicholas
FRC #0313
Oh, yes.. Hopefully the vacuum works for you guys =]
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Vacuums also keep the ball with you in turns and ensure only one ball is in possession. Most ball rollers have room for multiple balls and penalties are not good this year.
Good luck Falcons!
1058 PVC Pirates 2016 - xxxx
Unread 05-03-2010, 14:23
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
I know you've given up on the rollers, but let me give you a hint anyway as to what some teams figured out.
It's a whole lot easier to "wedge" the ball into 2 rollers so that it's actually held rather than trying to roll it backwards. Rolling it backwards depends on a lot of variables, especially the relative friction between your rollers, the ball, and the carpet. As long as the ball isn't off the ground when it's "wedged", you're fine.
Take a look at robowranglers video to understand better what I mean. Notice when they mistakenly drive up the ramp the ball comes off the floor? They're not spinning the ball - they've got it wedged.
Unread 08-03-2010, 15:14
sam3062 sam3062 is offline
FRC #3062
sam3062 is an unknown quantity at this point
We are a second year team and are having alot of trouble trying to configure a working vacuum mechanism to suction the soccer balls. Any advice you can give me on the parts that you used or how you hooked up the fisher price motor?
Unread 08-03-2010, 16:10
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
I hate to say it but I am under the impression that 148/217 is probably carrying the ball by a very small amount most of the time. In order to truly have the ball wedged like that the ball would need to come off the floor a small amount. I have also heard from some people who have prototyped these systems who echo the same findings. If they are not carrying then I'm truly impressed but otherwise teams should be very careful when creating these pinching systems.
Mentor 2415
Unread 08-03-2010, 16:21
santosh's Avatar
santosh santosh is offline
AKA: 2415
FRC #2415
santosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond repute
Send a message via AIM to santosh
we took a standard vaccuum cleaner's turbine and coupled the fisher price's shaft to be press fit into the the turbine.
President, VEX Robotics, Inc.
The referees at Finger Lakes were on their hands and knees checking out our system. They even pulled us (and 188) to the practice field to prove it to them. When we proved that the ball never leaves the ground when driving around the flat part of the field, they agreed.
We never got a penalty for carrying the entire regional. Even in the finals when we were the front zone scorer, the refs at both goals were always watching our robot to make sure we never lifted the ball. again, no penalties.
It is possible, but is very difficult to do. After each match we had to check the geometry because if it changes just slightly, you won't grab the ball.
And how we go up the scoring ramp without lifting the ball is our little secret...
In full disclosure I am the President of VEX Robotics, a division of Innovation First International.
Unread 08-03-2010, 18:05
Pat Major's Avatar
Pat Major Pat Major is offline
#0494 (The Martians)
Pat Major has a reputation beyond reputePat Major has a reputation beyond reputePat Major has a reputation beyond reputePat Major has a reputation beyond reputePat Major has a reputation beyond reputePat Major has a reputation beyond reputePat Major has a reputation beyond reputePat Major has a reputation beyond reputePat Major has a reputation beyond reputePat Major has a reputation beyond reputePat Major has a reputation beyond repute
At Kettering two teams had the two bar system and when they put their front wheels on the ¾ inch plywood at the base of the bump they were both carrying the ball. A piece of paper was slid under the ball. Both teams agreed that they were indeed carrying the ball at that point and had to avoid that area when they had a ball or risk a penalty. They were also carrying the ball if the front of the robot went into the goal and there was no floor left under the ball. They solve this issue by not driving into the goals.
A river is powerful because many drops of water have learned the secret of collaboration.
Unread 08-03-2010, 18:19
Karthik Karthik is offline
VEX Robotics GDC Chairman
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
I'll give away the simple solution for teams using the "pinching" method of grabbing the ball who happen to lift the ball in the manner that Pat described; Put your roller system on a pivot and spring load it down. We have done that and it ensures that our ball always stays on the ground, even when our back wheels are on the carpet and the ball is on the plywood lip in front of the bump.
Now, teams like 188 and 217 in Rochester had pinching rollers, which weren't spring loaded, but they managed to keep the ball on the ground with no difficulties. This just goes to show that there are multiple ways to solve this problem.
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
Unread 08-03-2010, 18:26
RMS11's Avatar
RMS11 RMS11 is offline
Safety!!!!
AKA: Rick
FRC #2415 (WiredCats)
Team Role: Driver
RMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to behold
Send a message via AIM to RMS11
One question about your duel rollers. Are they both motorized or is one just there to stop the ball from jumping the robot and going too deep into the bot?
2009 Peachtree Regional Champs
2009 Palmetto Regional Champs
2008 Peachtree Rookie All Star and Rookie Highest Seed
Unread 08-03-2010, 18:33
The top roller is motorized, while the bottom part of the system is just a passive steel bar wrapped in rubber.
Unread 08-03-2010, 20:57
AKA: Sean
Thanks for clarifying this paul. My initial thoughts were that you had to be carrying to get a grip like that but in the back of my mind I figured you guys weren't willfully playing the system. I guess I might be protoyping a pinching roller here in a bit although Im quite a fan of the vacuum systems as well. It just goes to show theres definitely multiple ways to handle the possession of the ball this year.
Mentor 2415
paper: 842's Chairman entries N7UJJ Extra Discussion 1 02-12-2009 02:37
pic: View of 842's Shoot kE7JLM Extra Discussion 12 31-01-2009 11:55
pic: 842's Robot Chassis - Carmen cheesed rear falconmaster Extra Discussion 11 07-01-2009 01:37
Team 842's ROV for NURC kE7JLM Off-Season Events 4 19-05-2008 14:03
Slow-Mo Videos of 842's Robot Virginia's Dream kE7JLM Robot Showcase 2 20-02-2008 12:12
