Go to Post Some companies cut costs (and cut corners to do so). Some work hard to build loyal customers. Which would you rather purchase from? - sanddrag [more]
Unread 07-03-2010, 22:46
biojae's Avatar
biojae biojae is offline
Likes Omni drives :)
AKA: Justin Stocking
FTC #5011 (BOT SQUAD) && FTC#72(Garage bots)&& FRC#0399 (Eagle Robotics)
biojae is a jewel in the roughbiojae is a jewel in the roughbiojae is a jewel in the rough
Flash memory available?
Is there a function that allows us to find out how much space in flash memory is free and is available for other files (ie camera images) in vxworks?
FTC Team 72 - No site
FRC Team 399 - http://www.team399.org
2010 Rockwell Collins Innovation in Control Award - (Use of the CAN bus, among other reasons) Phoenix, Arizona!
Unread 08-03-2010, 02:04
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: Flash memory available?
relFsShow ("/c");
Unread 08-03-2010, 02:23
biojae's Avatar
Originally Posted by jhersh View Post
relFsShow ("/c");
And this returns a struct of type STATUS?
What variables are in that struct?
Unread 08-03-2010, 02:33
This function prints to stdout... the status is what you would expect from an application in a shell... i.e. 0 == success non-0 == failure.
-Joe
Unread 08-03-2010, 16:49
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
-Joe
are you saying we have to redirect stdout?
Watchdog.Kill();
Unread 08-03-2010, 19:13
If you need to do this from within your program and you were going to use this entry-point, then yes... I was thinking you would call it from the console to find out.
I'll do some more research to find the entry-point that is designed to be called from within your application.
-Joe
cRio memory bobwrit FRC Control System 3 25-07-2009 01:34
Help||Saving data to Flash memory & Encoder Nimrod Beker Programming 5 11-02-2009 09:27
crio flash memory Bwood16 Programming 1 06-02-2009 18:55
How to Flash A Controllers Memory Steve Ketron Programming 1 23-10-2008 09:03
Increasing available program memory DanDon Programming 21 30-05-2005 17:00
