Go to Post We tried to get clear aluminum, but it was on back order. They said it would be in by March 3, 2150. - S.Nickens [more]
Unread 08-03-2010, 12:09
Joining the 900 Meme Team
FRC #0079
Re: Best 2010 Lifter
Originally Posted by johnr View Post
There is something else about 2337. When they lock on there is this sound. It just sounds-- strong. I was in the pits and just knew it was them. I don't remember, and maybe someone from 2337 could answer this, could a team like 27/33 lock onto you and then you lift or is your structure made out of square tubing?
2337's lifter has a series of pins. When the lifter raises up one set of pins is pulled out of place releasing the lower supports, once the hooks connect (or more accurately swing past a certain point) it releases some pins out which is what lets the upper structure slide up and down on the support poles. The sound could also be the mass of the structure hitting the tower, there is a lot of mass moving quickly and all the bodies are hollow. Either way, it is a nice sound no?
To answer your next question; not as the system works now. One of the parents did some math and figured out that the load on the vertical supports exerted by 27/33 style lifters is ~2x what the structure can support. Realistically the vertical support beams don't support any of the robots hanging off of us it is only the upper pseudo tower that is supporting additional weight. This MAY change but I do not know.
3rd: Those poles are the same diameter as the tower so that if a hook works on the tower it will work on the pseudo tower.
Hope I answered your questions.
EDIT: Clinton beat me.
Unread 08-03-2010, 12:19
maltz1881 maltz1881 is offline
maltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant future
No doubt about it Teams 2337, 27 and 33 have the best designs when it comes to hanging. Team 2337 the NERDS have the best design to have others hang from them.
Unread 08-03-2010, 12:33
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is online now
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Maybe your opinion (I havent seen them so I can't say for sure)
... But I'd match teams 78 and 151 hanging systems up against just about anyones. Quick and effecient.
___________________
- Tennyson, Ulysses
Unread 08-03-2010, 13:12
Graham Donaldson's Avatar
Graham Donaldson Graham Donaldson is offline
AKA: Graham Donaldson
FRC #1676 (The Pascack Pi-oneers)
Graham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant future
Some really good hangers at NJ that pop into my head: 25 (a very similar setup to 148, even though they've taken theirs off), 1672, 1676 (I may be biased but ours was one of the better ones there). 2016 and 2753 weren't too shabby either.
2008 NJ Regional, 2009 Palmetto Regional: Chairman's Award Winners
2010 NJ Regional Champions (w/ 25 and 3059), 2010 VA Regional Champions (w/ 1086 & 1418)
"Hard work spotlights the character of people: some turn up their sleeves, some turn up their noses, and some don't turn up at all."- Sam Ewing
"Opportunity is missed by most people because it is dressed in overalls and looks like work."- Thomas Edison
Unread 08-03-2010, 13:53
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Originally Posted by thefro526 View Post
The best lifter at The New Jersey Regional was 25 without a doubt. Their mechanism was both unique and fast, but I won't go into too much detail here. I believed it was dubbed "The Strong Man Hang" by the announcer at NJ...
25 seemed to have problems with hanging in the eliminations at Jersey. It looked like their mechanism that slid them up the bar after rotating up failed to go up high enough.
2001-2004: Team 100
2006-Present: Team 254
Unread 08-03-2010, 14:09
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
In the matches I saw 25 play, I only saw them miss one hang which was when they ran out of time and missed by about 1/2" or so.
I think they hung in one of the finals matches against us but I'm not entirely sure.
-Dustin Benedict
Unread 08-03-2010, 14:23
nuggetsyl's Avatar
nuggetsyl nuggetsyl is offline
FRC #0025
nuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond repute
During the very gentle playoff matches in nj (hehe) A bar bent that kept us from getting up all the way. We will have a much stronger one build for las vegas.
00,12Championship winner
03,06,08 Championship finalist
02A,03C,06N,08C,11N,12G Division winner
00,03,06,07,08,10,12 NJ / MAR winner
11 VCU winner
06,10 Las Vegas winner
12 MAR Mt Olive
red is for team 348
Unread 08-03-2010, 14:46
One of the other problems, maybe in the final match, was that the post on the inside of the bar (25'd be able to describe it better) wasn't flush up against it, and became a sort of hypotenuse, meaning they couldn't get up all the way.
Unread 08-03-2010, 18:06
Back @ it again with the white vans
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
We, along with 2016, are tied for most lifts in NJ. We coulda had more but had SO many problems in the elims, we didn't even get one hang in.
I didn't get a chance to see 2016's but heard it was good.
Unread 08-03-2010, 18:18
Noah Booth's Avatar
Noah Booth Noah Booth is offline
1922: Top Seed NH. Winner MA.
FRC #1922 (Oz Ram)
Team Role: Driver
Noah Booth will become famous soon enough
The best I have seen by far is team 78 at Manchester. their arm was fast and efficient and did not take away from the rest of the game. team 151 also lifted quite well. does anyone have a video of team 25. I have heard so much about them on cd but not seen any media.
Unread 08-03-2010, 18:34
jblay's Avatar
jblay jblay is offline
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
At NJ 25 had an awesome hanger. 2016 and 2753 had two awesome telescoping arms that were really quite brilliant and we may have to replicate the idea in the future.
1717 who hasn't been seen by most because sandiego wasn't web casted has an amazingly fast and cool hanger
they hang at the end of this video:
http://www.youtube.com/watch?v=H-e7_Cyp8iA
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
Unread 08-03-2010, 18:51
pfreivald's Avatar
AKA: Patrick Freivald
We manage to hang in the last match for the first time right at the end of the match but unfortunate so did 1551 (they would have won anyways even if they didn't make it up).
...but we just had to, man. It's what we were born to do.
If I may brag a moment (because in six years I've never had a *robot* to truly brag about, even if I've had a team that is awesome), I believe that 22 hanging points puts us at the top of the ladder for week one...
But that said, 1717's lift is *freaking amazing*. I love it. It's the only one I've seen so far that might be faster than ours.
Well done, 1717, well done.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 08-03-2010, 18:55
enigmatic enigmatic is offline
FRC #2075
enigmatic is an unknown quantity at this point
Our team currently cannot hang (which we might be changing) but i still only saw one team at kettering that i would feel comfortable attempting to suspend from and that was the 2337
25 hands down.
I will toot 11's horn about speedy hanging once I have video (we only hung once in NJ and didn't have it set to raise high enough)
Unread 08-03-2010, 20:08
rocknthehawk's Avatar
rocknthehawk rocknthehawk is offline
AKA: Aaron
FRC #1768 (Robo Chiefs)
rocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to behold
78 had an impressive lift.
I'd have to say 126....but I'm a bit biased.
No Lifter = No Playoffs dmoody92 General Forum 21 12-03-2010 22:41
Team 997 Lifter pakratt1991 Robot Showcase 24 09-04-2007 02:44
pic: 997 Lifter pakratt1991 Extra Discussion 2 08-03-2007 19:33
pic: Team #39 lifter Ken Loyd Robot Showcase 1 21-02-2007 11:54
Who's a Lifter? LordKronus Rules/Strategy 2 21-01-2007 00:00
