Re: v89 Jag used for CAN, trouble going back to PWM?
We switched to CAN and back with few problems. Now the status light on the Jaguars sometimes flashes on the black jaguars when it is a neutral signal, despite having a good pwm signal and working.
Did you check to see if, in the bdc-com terminal, you disabled heart beat? |
| pic: cRIO CAN Jag | Andrew Schuetze | Extra Discussion | 63 | 25-07-2009 01:48 |
| Can one PWM control 2 Victors for Tandem Motors | ericsundbergva | Control System | 1 | 18-02-2008 04:55 |
| Trouble Generaing PWM output | RaiderRev | Programming | 3 | 22-01-2008 18:59 |
| How much of our wheel used for the shooter can be exposed? | waialua359 | Technical Discussion | 4 | 14-02-2006 13:27 |
| Trouble with pwm outputs | misterikkit | Programming | 16 | 17-01-2004 10:56 |
