Go to Post It would also level the playing field by bringing the bottom up, rather than the top down. - russell [more]
Unread 08-03-2010, 20:09
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Need help with timing auton
This VI makes some assumptions about your robot, most importantly about the pneumatics. The VI is written assuming you are using a single acting solenoid that "fires" when set to true and the cylinder retracts using springs or some other method when set to false.
If you need help fixing the pneumatics code up for your setup, please post details about the process you want the pneumatics to go through (single or double solenoid, which side to set when, etc.)
need help with a rule! mahmosh Rules/Strategy 4 15-02-2009 13:56
Need help with IR as an Input AdmiralAllen Electrical 3 11-02-2008 14:22
Help with auton switching code farmer Programming 3 15-02-2005 15:30
hey need some help with writing a code please help me here magical hands Programming 9 01-01-2004 21:46
Need help with C++ Tton Programming 7 04-11-2003 19:15
