Go to Post if you do make a marshmallow robot, that would be pretty sweet. - smurfgirl [more]
Unread 08-03-2010, 20:05
dnrobotics11 dnrobotics11 is offline
FRC #2589
dnrobotics11 is an unknown quantity at this point
Relay Code
Hi everyone,
I have a quick question about the C++ code for spike relays. What are the two arguments in the phrase "relay(x, y)" when I am initializing the relay in the code? One of them is clearly the relay port but what is the other and what is the order of them? Thanks a lot.
Unread 08-03-2010, 20:45
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Re: Relay Code
you only need one if you are using slot 4 (default)
if you are not in slot 4, the first is the slot (if it is not 4, it's probably 6), the second is the relay port (on the DSC)
if you have it in 4, use relay(relayPort)
Watchdog.Kill();
Unread 08-03-2010, 21:31
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Re: Relay Code
There are two possible constructors for the Relay class (from relay.h). Here are their definitions:
Relay(UINT32 channel, Direction direction = kBothDirections);
Relay(UINT32 slot, UINT32 channel, Direction direction = kBothDirections);
You can find the header files in c:\windriver\vxworks-6.3\target\h\wpilib.
Unread 08-03-2010, 23:03
FRC #2589
Re: Relay Code
thanks so much guys
spike relay code urgent chris janney Java 1 21-02-2010 17:55
Relay Robopanda6 Java 5 07-02-2010 01:08
Spike relay code not working wywern209 Programming 9 05-02-2010 22:04
C++ Relay Code? Happyisgood C/C++ 10 16-07-2009 14:54
Intermittent CODE ERROR, followed by uncommanded relay switching tcj103 Programming 4 22-01-2007 02:59
