Go to Post Wait, robot? We've been working on building a team. - rtfgnow [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 08-03-2010, 22:12
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Commanding Speed in a Negative Number Results in Runaway
I'm playing with CAN set Speed a bit in Java and DBC-COMM and setting a Speed of negative RPM causes the jaguar to command full speed. It seems the jaguar doesn't understand a negative RPM value.
Unread 09-03-2010, 00:17
duane's Avatar
duane duane is offline
FRC #0701 (RoboVikes)
duane is an unknown quantity at this point
Send a message via AIM to duane
Re: Commanding Speed in a Negative Number Results in Runaway
This is purely a guess. It's not a negative value but rather an unsigned value. Which translates a negative value into a very large positive value.
That's purely a guess based on experience as a programmer. :-)
Duane Murphy
Mentor - Software
Vanden Vikings FIRST Team 701
http://www.vandenrobotics.com
Unread 09-03-2010, 11:13
Kingofl337's Avatar
AKA: Adam
I'm pretty sure this is the issue also, probably in the Jaguar firmware.
Unread 12-03-2010, 11:55
dyanoshak dyanoshak is offline
AKA: David Yanoshak
FRC #2158 (ausTIN CANs)
dyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond repute
Hi Adam,
Are you seeing this on a Gray or a Black Jag?
What firmware version are you running?
What are your PID values?
-David
Unread 12-03-2010, 22:28
Kingofl337's Avatar
AKA: Adam
Black Jags,
Firmware 89,
PID 2, .0001, 6
US Digital Kit Encoders 360cpr
I posted sample code on the 2010 beta site
Unread 15-03-2010, 11:25
AKA: David Yanoshak
Hi Adam,
We were able to recreate what you're seeing on my setup here. After doing some testing we noticed that there is a small bug in the PID code that makes the reverse direction more sensitive to PID tuning.
Correct me if I'm wrong, but I bet you tuned your PID constants in the forward direction first, and then tried to move in reverse (I did the same thing). I would try tuning your PID in reverse first. It should be possible to tune in reverse, even with the bug.
I would try lowering P and possibly D and see if that helps tuning in the reverse direction. Once tuned in reverse, forward should work just as well.
We are currently working on a bug fix and the best plan of action on releasing an update if it is deemed necessary.
Thanks for your input and please keep me posted!
-David
Unread 15-03-2010, 15:55
Kingofl337's Avatar
AKA: Adam
if FIRST doesn't want you to release an update, I'd be willing to test a beta version of the fix.
Unread 17-03-2010, 19:42
AKA: David Yanoshak
There is new firmware that should fix this issue. Please see this thread: http://www.chiefdelphi.com/forums/sh...852#post938852
-David
Negative Repping... Cody Carey General Forum 21 29-03-2007 18:42
No Negative Scores? ahecht General Forum 3 05-03-2005 01:41
Negative Scoring Mr.G Rules/Strategy 16 14-02-2005 11:02
Negative Bus Greg General Forum 3 03-02-2003 07:33
Negative Scoring BBFIRSTCHICK Rules/Strategy 4 12-01-2003 03:55
