Go to Post Don't let my students know I skimmed that blog and didn't read it thoroughly. - rlance [more]
Unread 08-03-2010, 23:36
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Re: Power Management Recommendation for driver stations
Originally Posted by eugenebrooks View Post
Using an inverter has its hazards, but it would be entirely
reasonable to have a dc to dc converter powered by a robot
battery, or any other battery, to keep the classmate topped
off between matches. It is a simple matter to match the voltage
and connector used to charge the classmate.
Eugene
Proprietary connectors and unique, non-standard, voltages make this hard. even once you get the voltage AND CURRENT to the proper value, the connector might need to be spliced in a manner that could be deemed unsafe, plus prone to failure. But, I am no expert on classmate power supply cables and connectors. If this wasn't first, I would suggest soldering a car dc connector (lighter) onto the battery to plug the inverter into, but, this is FIRST, so we can't do that. I hate proprietary connectors!
Laptop recommendation for inventor/pro/e/etc Zyrano CAD 6 28-01-2010 23:20
"vertran" teams not getting the new driver stations?!?! BEEKMAN FRC Control System 6 06-11-2009 20:10
Power Driver Station with Serial pyr0b0y Technical Discussion 6 30-04-2009 19:53
Power for Driver Station mutantblond Technical Discussion 26 11-03-2009 01:20
Laptop for FRC Labview: Recommendation Wanted Foster National Instruments LabVIEW and Data Acquisition 2 22-11-2008 21:14
