Go to Post Weight down low is a good thing. Weight up high is not. - s_forbes [more]
Unread 08-03-2010, 22:23
seed points calculator
Enter RED and BLUE alliance scores and penalties into cells A2 thru D2...
see how many seed points each alliance gets.
enjoy :-)
3/9/10 5:57pm updated for Team Update 16 seed points rule change.
Unread 08-03-2010, 22:47
lancerbots lancerbots is offline
FRC #2367
lancerbots is an unknown quantity at this point
Re: seed points calculator
thank you! this should help in the Silicon Valley Regional
Unread 08-03-2010, 22:53
AmoryG AmoryG is offline
FRC #2423 (KwarQs)
AmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud of
enjoy :-)
Looks good, but does your calculator work with a theoretical negative score?
KwarQs 2423
2008 Boston Regional Rookie Allstars
http://whsrobot.blogspot.com/
Unread 09-03-2010, 00:00
CurseofDragon33's Avatar
CurseofDragon33 CurseofDragon33 is offline
AKA: Thomas Yuricek
FRC #0048 (Delphi E.L.I.T.E.)
Team Role: Scout
CurseofDragon33 will become famous soon enoughCurseofDragon33 will become famous soon enough
Send a message via AIM to CurseofDragon33
Thank you very much! This might help me understand this system.
Thomas Yuricek
Delphi E.L.I.T.E.
Team 48
Competition/ Scouting Collegiate Mentor
Unread 09-03-2010, 07:20
If by "theoretical negative score" you mean that the penalties exceed the score, then the answer is yes, it works.
Try it.
Highest rookie seed Nitroxextreme General Forum 38 11-03-2008 13:54
YMTC: #1 Seed Don Wright General Forum 25 04-04-2006 18:18
pic: YMTC: 150 points or 100 points? CD47-Bot Extra Discussion 4 25-03-2004 01:53
Record #1 Seed? /Pyro General Forum 2 15-04-2003 22:09
Second seed vs. 9th seed Mr. Van General Forum 11 04-03-2002 01:27
