Go to Post I can see the 2013 Kickoff broadcast now: "Hello Teams. Welcome back. Gracious Professionalism. Here's some homework. Here's the animation. Here's what the actual field looks like. RTFM. Peace." - sanddrag [more]
Unread 07-03-2010, 23:02
DtD's Avatar
DtD DtD is offline
I hope the watchdog starves!
AKA: Pathogen David
FRC #2410 (The Metal Mustangs (Merged from 2334, Hazmat Robotics))
DtD will become famous soon enoughDtD will become famous soon enough
Re: Power Management Recommendation for driver stations
We just made sure our classmate was always plugged in between matches, and plugged in over night. (Don't just power it off over night, the classmate phantom will suck down the battery anyway - no I'm not putting it in sleep mode.)
~David
Unread 08-03-2010, 01:29
Mike Hendricks Mike Hendricks is offline
misses his IFI control system
FRC #0973 (GRR)
Mike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to all
Ed,
The venue should be able to dig a few power drops out of their house box in a minute or two. All it requires is a threeway extension cord at each player station.
It really shouldn't even take that long considering there already is AC power at the drivers station for the SCCF cases, as well as additional power drops for the fixed cameras on the corners of the field. I was surprised that FIRST didn't provide the ability to plug the Classmate into power on the field. It will be interesting to see how these PCs hold up in Atlanta, and if any delays are caused by teams are waiting for the laptops to wake up or if they fail from the long walks or waits in the queue.
While we didn't have any issues last weekend in San Diego with ours, there was a few rounds where our battery was dangerously low. Plugging it in when the bot was in the pit helped, but there really should be something on the field to plug them into. It's very likely that the veteran teams will need to reuse PC next year, and who knows what shape the batteries will be in by then. Maybe someone will donate batteries for the KoP
2004-2010: Founding Member, Technical Mentor - Team 1388, Eagle Robotics
2011: ???
Unread 08-03-2010, 07:19
IceStorm IceStorm is offline
Mentor FRC 5046, FTC 8688
AKA: Chad
FRC #5046 (Jacked Up Jackets)
IceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of light
Send a message via AIM to IceStorm Send a message via Yahoo to IceStorm
Just out of curiosity how long were the inverters staying running on one of the robot batteries? I had thought of doing this at some point on Friday but wasn't sure how long of runtime you would get before you would need to recharge the batteries.
Unread 08-03-2010, 07:57
Originally Posted by ebarker View Post
Roger that, I copy your comments well !!
However I posed the question to someone in the know at the event and the answer was negative.
Who controls the field facilities ? The GDC ? FIRST engineering ?
The question needs to be asked because without consistent guidance from HQ there is going to be some confusion.
Our cart now has AC power on it so our alliance members can stay plugged in and charging during queueing. And we have a handheld AC kit for the opposing alliance so they can go ditto !!
When the teams move forward they can pull the plug and place their equipment onto the driver stations. All that doesn't interfere with any understanding that FIRST has at this moment.
Should I post this to GDC Q&A ?
Ed,
It is my understanding that each event is slightly different. Most often the local regional committee is the one paying for the venue and services it provides. I have never had a problem asking for additional power in the Inspection area. I am concerned about power cords running between robot carts while in the queue for obvious reasons. If someone had thought of this before, there should be power at the driver's station for all robot control. The old IFI controllers were powered by the field when you plugged in.
Unread 08-03-2010, 08:28
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
Ed,
I have never had a problem asking for additional power in the Inspection area. The old IFI controllers were powered by the field when you plugged in.
Al,
If they are using the same field then I'd expect the power is still there ? I think it used to have about 4 outlet boxes built in for the IFI controllers.
I'll push the issue to the GDC so they can comment. Then students going to the next event can carry that doc with them and then they can meet with the event organizers on site. I'm concerned that the venue will resist this unless there is GDC guidance.
I'd imagine if the head inspector want more power well then "Captain we got to have more power !!" ( in my best Scottish accent ). I can see why you would not have a problem getting power.
We have run video equipment that uses more power than the classmate and we have run all day long, EASY !
We also use this setup to run public demonstrations outdoors and corporate / legistaive events indoors. All day long EASY !
Put the battery on the charger overnight. Check the battery midday while inverting just to make yourself comfortable.
Ed Barker
Unread 08-03-2010, 20:17
Alex Dinsmoor's Avatar
Alex Dinsmoor Alex Dinsmoor is offline
Are our seeding points over 9000?
FRC #0201 (FEDS)
Alex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant future
Send a message via AIM to Alex Dinsmoor
My team actually uses this method to power our control system when we do parades. It allows us to drive the robot while moving!
The batteries last a whole day powering a control system, with heavy use. You should have no problem with one or two batteries charging your classmate throughout the day.
Although this year at Kettering we were shut down by a safety captain when we were using a robot battery to power something besides the robot... You should probably get a clarification from FIRST that this is a "safe" activity before using the battery solution.
'08, '09, '10
4 Years | 14 Competitions | 194 Matches | 119 Wins | 77 Losses | 2 Silver | 1 Gold
Unread 08-03-2010, 21:52
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
I asked about player station power at KC.
The power that is normally run to the player control area is now ued to power the ball return timers (in the goals and in the return rack).
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 08-03-2010, 22:15
ebarker's Avatar
AKA: Ed Barker
Ask the 'safety captain' to cite the hazard !
If you have a UL approved inverter using the same Anderson connectors in the KOP using properly insulated wire ?!?! then they need to cite the hazard. Ask for the lead safety person.
Ed Barker
Unread 08-03-2010, 22:31
AKA: Dr. Brooks
no team (WRRF)
Using an inverter has its hazards, but it would be entirely
reasonable to have a dc to dc converter powered by a robot
battery, or any other battery, to keep the classmate topped
off between matches. It is a simple matter to match the voltage
and connector used to charge the classmate.
Eugene
Unread 08-03-2010, 23:36
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Eugene
Proprietary connectors and unique, non-standard, voltages make this hard. even once you get the voltage AND CURRENT to the proper value, the connector might need to be spliced in a manner that could be deemed unsafe, plus prone to failure. But, I am no expert on classmate power supply cables and connectors. If this wasn't first, I would suggest soldering a car dc connector (lighter) onto the battery to plug the inverter into, but, this is FIRST, so we can't do that. I hate proprietary connectors!
Unread 09-03-2010, 00:31
AKA: Dr. Brooks
no team (WRRF)
If you look at the connector, voltage and current limit, you
are likely to find an existing dc-dc converter for a laptop that
fits the bill without using an AC inverter.
Eugene
Unread 09-03-2010, 08:09
ebarker's Avatar
AKA: Ed Barker
wrong wrong...
a) use a standard robot battery with standard Anderson connector
b) use a COTS DC-AC inverter. Sometimes the inverter comes with pigtails in the kit. One is simply plain wire. Fit inverter with a standard Anderson connector.
Then you can pull any battery out of your battery pool to run the inverter for demos, presentations, competition, etc.
The solution Eugene talked about is more elegant and suited to a dedicated application. This solution give you power on the go for classmates, hubs, routers, laptops, and is more general purpose.
I have this inverter - it has pigtails the are interchangeable. I got it at a truck stop
I have this one too - you put it in your cup holder in your truck or car.
It doesn't give you enough power to run a cotton candy or squishee machine.
Ed Barker
Unread 09-03-2010, 11:01
Or make a simple Anderson SS50-to-cigarette lighter adapter so you can use the inverter without modification.
With the cigarette lighter adapter, you get even more options. We have a small handheld 12v vacuum cleaner that's been used on occasion with a robot battery. We also used an automotive FM transmitter to put the audio through the shop speaker system when we watched a DVD.
Unread 09-03-2010, 11:11
Andrew Y.'s Avatar
Andrew Y. Andrew Y. is offline
FunYun
AKA: Andrew Yun
FRC #2415
Andrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud of
battery would not be as big of a problem of 832 and 2415 stopped being on the field at the same time. Together we caused the FMS to shut down about 3 times...and thats when peoples batteries suffered
Unread 09-03-2010, 11:13
We've used ours to power a car compressor to blow up balls over the years.
Laptop recommendation for inventor/pro/e/etc Zyrano CAD 6 28-01-2010 23:20
"vertran" teams not getting the new driver stations?!?! BEEKMAN FRC Control System 6 06-11-2009 20:10
Power Driver Station with Serial pyr0b0y Technical Discussion 6 30-04-2009 19:53
Power for Driver Station mutantblond Technical Discussion 26 11-03-2009 01:20
Laptop for FRC Labview: Recommendation Wanted Foster National Instruments LabVIEW and Data Acquisition 2 22-11-2008 21:14
