Re: Raw Voltage on Cypress
It's quite easy to wire up a few LEDs.
I haven't seen many teams driving LEDs directly from the PSoC board without using the HC outputs. 968 developed a LED driver board that uses small power transistors to switch our LEDs. This allows us to drive multiple LEDs(5 of them) without going over the PSoC limits. |
So my real question: what is the BEST solution for wiring up a lot of LEDs on the OI? |
How many, exactly? Are they all controlled independently?
If I remember correctly, they want to put a 7-segment LED display (or a row of LEDs) on to indicate the kicker "power level" they're requesting of the kicker (insert >9000 reference here...), individual LEDs to give camera feedback to the driver (one LED means they're aimed too far left, one means too far right, and a center one means they're ready to kick), a single LED to indicate that the kicker leg is wound and ready to release.
The idea of using "super bright" LEDs is that the driver doesn't need to wear an annoying, clunky HUD. Rather, it will be very obvious from peripheral vision and ambient light to know what the robot's state is (different color LEDs at different positions indicate different things). |
An additional question: are we permitted to make an LED driver circuit, such that the cypress board sends a digital signal that turns the LEDs on, but they are powered from a small 12v battery on board the OI (I think this would required using a transistor)? I can't find anything in the rules that prohibits this, and I have a feeling this would be legal as per <R82>...
| Cypress board | bls0620 | Electrical | 4 | 17-01-2010 23:22 |
| Cypress soc? | sp33chy | FRC Control System | 2 | 15-01-2010 08:58 |
| Raw Camera Data | WatersongX | C/C++ | 8 | 03-02-2009 09:20 |
| Served Raw Chicken at Burger King. | MattK | Chit-Chat | 19 | 10-11-2005 00:56 |
| Voltage Byte -> True Voltage | Ulibrium | Technical Discussion | 11 | 01-03-2002 08:55 |
