Go to Post And if you are unhappy about me using "robot", let me break your heart over what we've done to the word "cheesecake". - Foster [more]
Unread 17-02-2010, 15:54
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
Default function pinouts on Psoc I/O board
I feel like a dummy asking this, but I can't find out what the default pin/function mappings are for the Cypress board.
I have the "actual" pin/function designations, but where are the "compatibility" functions identified...
eg: there are 8 analog inputs on the board, but only 4 in the default "DS Compatibility" interface.... so.. I'm to assume that we only use analog channels 1,2,3 & 4 on the Cypress board??
But what about the digital channels.
DS Compatibility interface has 8 digital inputs and 8 digital outputs.
It "appears" that cypress digital channels 1-8 corrospond to the inputs, and 9-16 corrospond to the outputs, but I'm just guessing....
Is this written up anywhere? I'm assuming it is, I just can't find it.
Phil.
Phil Malone
http://www.GEARSinc.org
Unread 17-02-2010, 16:40
heydowns's Avatar
heydowns heydowns is offline
AKA: Jeff Downs
FRC #1511 (Rolling Thunder)
heydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond repute
Re: Default function pinouts on Psoc I/O board
I have not seen this documented anywhere. The closest thing is the default settings on the I/O tab of the driver station.
First 4, yes.
This is accurate with what we have observed and used in the past. The first 8 are inputs (I believe pulled up or floating, I don't recall which - last year's DS was floating, so that would be closest match, but I seem to recall observing these as pulled up).
The second 8 are outputs.
Note that if you were to move to the enhanced I/O configuration, you can make a definitive selection of each pin assignment, control direction of pull (or floating) on inputs, eliminating any doubt and guesswork.
Unread 17-02-2010, 20:16
Does this help?: http://www.chiefdelphi.com/forums/at...2&d=1264090529
Unread 09-03-2010, 04:57
The Lucas's Avatar
CaMOElot, it is a silly place
Does anyone know if the default Digital Outputs are configured for 4mA current source, 8mA current sink, or 25mA current sink?
I'm going to rewire an output and I would like to know what I'm working with. Thanks to the info on this thread I figured out we currently it connected to digital input 4 instead of digital output 4 (and that is why it is always on )
Robot Inspector
Unread 09-03-2010, 10:10
heydowns's Avatar
AKA: Jeff Downs
FIRST has since posted an "official" pin-out on www.usfirst.org/frccontrolsystem -- here's a direct link:
http://www.usfirst.org/uploadedFiles...t%20tables.pdf
It contains the information you are looking for.
It falls short in describing how the pin-out looks for compatibility mode, but its a modest guess (and the above info on this thread should do it). If you use enhanced IO, you can set it up however you wish and eliminate any guessing.
Unread 10-03-2010, 00:00
The Lucas's Avatar
I wired my output circuit to P6_4 (Digital Output 1) and it works fine (so I dont really have a problem, thanks everyone).
The FIRST pinout lists these modes for the digital pins:
All digital lines are configurable
− Open-drain input
− 5kΩ pull-up input
− 5kΩ pull-down input
− Active drive output
...o 4mA current source
...o 8mA current sink
My original question was whether the digital outputs are were configured for sinking or sourcing in compatibility mode. However, after looking over the FIRST doc again it appears the answer is both and my question was somewhat misguided. The FIRST Doc reads like the mode is Active Drive Output and that mode is capable of both sinking (8mA) and sourcing (4mA). I can't confirm this from my experience, all I can really say is it looks like Digital Out 1 is capable of current sourcing to the base of an NPN transistor in my circuit.
Robot Inspector
Windows "Malfunctioning USB Device" error with Psoc IO Board WarrenPW FRC Control System 2 11-02-2010 18:53
Wiring Switches to the PSoC board Raj1977 Electrical 13 07-02-2010 23:24
Camera Pinouts? kiettyyyy Programming 7 09-04-2006 10:12
Pinouts CronosPrime1 Programming 1 04-02-2006 22:54
RNet Pinouts archiver 1999 1 23-06-2002 23:18
