Go to Post In the end, if our products are crap, then people will not buy them. This is the risk of doing business, and the foundation of capitalism. - Andy Baker [more]
Unread 09-03-2010, 06:08
Triapod Triapod is offline
Triapod is an unknown quantity at this point
Vision Tracking and Movement
Autonomous -
Our programming team has not yet programmed using vision, but have taken a look at the default code given to track circular objects. We think that this system works great and are wondering how to move forward to program movement towards the ball. We wish to move towards the ball but not hit it (stop right before it) then activate the pneumatic kicking system.
We are wondering if we would be able to be able to determine distance to drive, or have to use a sensor.
Thank you
Unread 09-03-2010, 08:55
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
Re: Vision Tracking and Movement
We experimented with using the camera to detect distance to the target/ball, but it just isn't accurate enough (can someone correct me?). You can use dead reckoning, i.e. drive for a certain period of time and then stop since you can place the ball where you want, or you can use a sensor. Some teams are using ultrasonic sensors or IR sensors. The control system documentation goes into how to use an ultrasonic sensor for this purpose.
Unread 09-03-2010, 15:41
Won't this system (timing/distance) be highly inaccurate because the distance we place the balls apart may vary? Using a sensor places near the kicking system may work but being near the high power area may cause damage to the delicate machinery like the limit switches.
Unread 15-03-2010, 12:19
Have you tried using the ultrasonic sensor. How accurate was it in determining the distance of the ball. Dead reckoning seems to be too inaccurate in that the distance between the balls could vary making the effectiveness of the kicker less. The ball could also roll.
Unread 15-03-2010, 12:45
nathanww nathanww is offline
Hacker
FRC #1678 (Citrus Circuits)
nathanww is just really nicenathanww is just really nicenathanww is just really nicenathanww is just really nice
If you're really worried about accuracy, a three-stage hybrid system might be useful
1.The robot tracks the ball using the camera
2.When the ball becomes too close to track, or if the camera loses it, the robot moves into dead-reckoning mode
3.When a broken-beam sensor is tripped, the robot stops, kicks, and can start the cycle over again if neccesary.
That said, the balls don't move that much after they're placed. Dead reckoning is very susceptible to random variations in hardware, but a good encoder or inertial nav system can fix this.
Get yer robot source code here!
2010 FRC camera vision tracking delay, image processing lag pspeer C/C++ 18 18-02-2010 07:24
Vision tracking: Did they get it right? dbell FRC Control System 35 15-02-2010 02:23
Vision Tracking Camera picking up too much... taoistconvert Programming 8 24-01-2010 22:19
71's Vision Tracking Problems Bill Beatty Rumor Mill 7 19-04-2005 17:41
