Go to Post By the looks, 1114 has already figured out both #1 and #2. They're still behind 71, who is just about done with their robot for the 2012 season, is getting driver practice for 2011, and is working on their robot designs for the 2013 water game. You're still way behind. - EricH [more]
Unread 08-03-2010, 16:33
Noamr Noamr is offline
FRC #1574 (Miscar)
Noamr is an unknown quantity at this point
Tower question
Hi,
I'm sure this is written somewehre, but I just can't find it...
What is the external diameter of the tower poles? This is quite urgent...
Thanks in advance,
Noam
MisCar 1574
Unread 08-03-2010, 16:39
Clinton Bolinger's Avatar
Clinton Bolinger Clinton Bolinger is offline
FF - PureMichigan
FRC #2337 (EngiNERDs)
Clinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond repute
Re: Tower question
1.5" Outer Diameter.
-Clinton-
Unread 08-03-2010, 16:44
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Re: Tower question
Originally Posted by Craig View Post
the tower is made from 1-1/2" nominal pipe which has an actual outside diameter of 1.90" (inches)
No! This is a mistake that we made early on during the build season. (Source: GE-10029_rebB.pdf (Page 3 center diagram))
Jacob
Unread 09-03-2010, 06:25
FRC #1574 (Miscar)
Re: Tower question
Are you sure it's 1.5?? How can I understand that from the diagram?
Thanks for all the replies ,
Noam
MisCar 1574
Unread 09-03-2010, 06:48
FRC #1574 (Miscar)
Re: Tower question
Oh, by the way, I was refering to the vertical pole and not the horizontal one so it would not be in the center diagram - it would be in the upper diagram, but I can't find it.
Thanks again!
Unread 09-03-2010, 08:54
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Tower question
It's all the same stuff. It's all 1.5" diameter steel pipe. Please note that it's a not terribly standard wall thickness that's moderately thin. Be cautious of any point loading you're putting on it, as you may damage it.
Unread 09-03-2010, 09:19
Craig's Avatar
Craig Craig is offline
Drive it like YOU BUILT IT!
FRC #4976 (REBELS!)
Craig is an unknown quantity at this point
Re: Tower question
That statement in itself is mis-leading. There is no such thing as PIPE that has an actual outside diameter of 1.5"
PIPE sizes are defined in a PIPE schedule based on the Inside diameter (nominally) and what is called 1-1/2" pipe has an OD of 1.9" (this is what is referenced in the manual under tower construction)
I will check the drawings, it is possible that the tower is constructed from 1.5" TUBE which is actual outside diameter.
Founding member: Team #4976 GO REBELS!
Spent some great years with #2386
Founding Member: Team #843
Unread 09-03-2010, 09:32
Craig's Avatar
FRC #4976 (REBELS!)
Re: Tower question
I just confirmed with the field drawings
The top & sides of the tower are constructed from 1.5" CRS (cold rolled steel) DOM (drawn over mandrel) TUBE
ie the actual outside diameter is 1.500" (inches)
Tower question? May_Walter Rules/Strategy 7 11-02-2010 15:04
Tower Diagrams wwrobotics1452 General Forum 2 06-02-2010 16:24
Question About the Tower Prepclub1939 Technical Discussion 1 10-01-2010 16:56
Tower Dimensions Kpchem General Forum 10 10-01-2010 15:42
Icy Tower DanDon Chit-Chat 16 02-11-2006 14:05
