Go to Post kids these days, with their fancy aluminum sprockets, don't know how good they have it. - AllenGregoryIV [more]
Unread 08-03-2010, 16:33
Noamr Noamr is offline
FRC #1574 (Miscar)
Noamr is an unknown quantity at this point
Tower question
Hi,
I'm sure this is written somewehre, but I just can't find it...
What is the external diameter of the tower poles? This is quite urgent...
Thanks in advance,
Noam
MisCar 1574
Unread 08-03-2010, 16:39
Clinton Bolinger's Avatar
Clinton Bolinger Clinton Bolinger is offline
FF - PureMichigan
FRC #2337 (EngiNERDs)
Clinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond repute
Re: Tower question
1.5" Outer Diameter.
-Clinton-
Unread 08-03-2010, 16:44
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Re: Tower question
Originally Posted by Craig View Post
the tower is made from 1-1/2" nominal pipe which has an actual outside diameter of 1.90" (inches)
No! This is a mistake that we made early on during the build season. (Source: GE-10029_rebB.pdf (Page 3 center diagram))
Jacob
Unread 09-03-2010, 06:25
FRC #1574 (Miscar)
Re: Tower question
Are you sure it's 1.5?? How can I understand that from the diagram?
Thanks for all the replies ,
Noam
MisCar 1574
Unread 09-03-2010, 06:48
FRC #1574 (Miscar)
Re: Tower question
Oh, by the way, I was refering to the vertical pole and not the horizontal one so it would not be in the center diagram - it would be in the upper diagram, but I can't find it.
Thanks again!
Unread 09-03-2010, 08:54
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Tower question
It's all the same stuff. It's all 1.5" diameter steel pipe. Please note that it's a not terribly standard wall thickness that's moderately thin. Be cautious of any point loading you're putting on it, as you may damage it.
Unread 09-03-2010, 09:19
Craig's Avatar
Craig Craig is offline
Drive it like YOU BUILT IT!
FRC #4976 (REBELS!)
Craig is an unknown quantity at this point
Re: Tower question
That statement in itself is mis-leading. There is no such thing as PIPE that has an actual outside diameter of 1.5"
PIPE sizes are defined in a PIPE schedule based on the Inside diameter (nominally) and what is called 1-1/2" pipe has an OD of 1.9" (this is what is referenced in the manual under tower construction)
I will check the drawings, it is possible that the tower is constructed from 1.5" TUBE which is actual outside diameter.
Founding member: Team #4976 GO REBELS!
Spent some great years with #2386
Founding Member: Team #843
Unread 09-03-2010, 09:32
Craig's Avatar
FRC #4976 (REBELS!)
Re: Tower question
I just confirmed with the field drawings
The top & sides of the tower are constructed from 1.5" CRS (cold rolled steel) DOM (drawn over mandrel) TUBE
ie the actual outside diameter is 1.500" (inches)
Tower question? May_Walter Rules/Strategy 7 11-02-2010 15:04
Tower Diagrams wwrobotics1452 General Forum 2 06-02-2010 16:24
Question About the Tower Prepclub1939 Technical Discussion 1 10-01-2010 16:56
Tower Dimensions Kpchem General Forum 10 10-01-2010 15:42
Icy Tower DanDon Chit-Chat 16 02-11-2006 14:05
