Go to Post Goodness, YES. Please get a copy of the rules. It explains a lot, and if your robot does NOT follow the rules, you will not be allowed to compete. Really, it is very important. - DonRotolo [more]
Unread 09-03-2010, 00:02
csshakka csshakka is offline
FRC #0818
csshakka is an unknown quantity at this point
Send a message via AIM to csshakka Send a message via MSN to csshakka
Iterative Robot Template
This may be a really dumb question that i overlooked the answer to, but should the drive controls in teleop mode go under the teleopContinuous() function or the teleopPeriodic() function. For simplifying purposes, lets say it would be for a standard tank drive robot with a left and right joystick controlling its movement. I guess my main question is where to code most of the controls and how often the periodic function actually is called.
Thanks in advance for help.
EDIT: Also what types of things would go in the disabled functions. Im assuming it would be things like motors to zero power and things like that.
Unread 09-03-2010, 06:54
charrisTTI charrisTTI is offline
Ramblin' Wreck
AKA: Charles Harris
FRC #0623
charrisTTI has a spectacular aura aboutcharrisTTI has a spectacular aura about
Send a message via AIM to charrisTTI
Re: Iterative Robot Template
teleopPeriodic is called about every 50ms. This time period is based upon the data rate of new packets coming from the driver station. New joystick information is received about every 50ms, so there is no reason to update the robot drive more frequently, since the data would be exactly the same as the previous data.
So put your call to tank drive in teleoPeriodic.
    public void teleopPeriodic()
        // feed your watchdog
        Watchdog.getInstance().feed();
        // drive the robot
        this.robotDrive.tankDrive(leftJoystick, rightJoystick);
FRC 623 2003,2004,2005,2006,2007,2008, 2009, 2010, 2011
FRC 1900 2007
FVC 60 and 193 2006
FVC 3271 2007
FTC 226 and 369 2008, 2009, 2010, 2011
FTC 3806 2010
Unread 09-03-2010, 09:42
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
yes the teleopPeriodic method is the one that makes most sense for competition. You can assume that each of the periodic functions in the iterative robot class are loops.
So the disabled method is good for handling chores you want taken care of before the robot is enabled in either autonomous or teleop. As you stated you can initialize all of your motors, variables, digi i/o, whatever. Also we are using the disabled method to set our autonomous mode. Pulling a trigger on one of our joy sticks will cycle through our auto modes that will be called once autonomous is entered. Yes the program still reads input even though disabled. You just don't get output to the robot.
I don't need a signature.
Unread 09-03-2010, 10:17
It is called at the rate of the new packets coming from the DS. However, that rate is 50hz (every 20ms).
Unread 09-03-2010, 10:36
FRC #0818
Alright makes much more sense. Thanks a ton everyone. Now its time to code it .
Unread 09-03-2010, 13:40
ideasrule's Avatar
ideasrule ideasrule is offline
FRC #0610 (Coyotes)
ideasrule is a jewel in the roughideasrule is a jewel in the roughideasrule is a jewel in the roughideasrule is a jewel in the rough
If you've run drive code on the robot before, I'd strongly suggest testing the code before going into a match. Chances are, no matter how simple the code seems, you'll need to tweak it countless times before getting it to work.
Iterative Robot Template? jalburty C/C++ 4 08-04-2011 13:57
Autonomous (Iterative) j.cole NI LabVIEW 6 12-02-2010 02:01
Iterative Robot demo mandrews281 C/C++ 0 21-03-2009 15:45
Continuous vs. Autonomous in Iterative Robot Shira C/C++ 4 06-02-2009 04:20
C++ Robot: Simple or Iterative? Abrakadabra Programming 3 14-01-2009 22:01
