Go to Post the usual Canadian thing - Karthik [more]
Unread 08-03-2010, 01:02
imac256 imac256 is offline
AKA: Ian McInerney
FRC #2022 (Titan Robotics)
imac256 is a glorious beacon of lightimac256 is a glorious beacon of lightimac256 is a glorious beacon of lightimac256 is a glorious beacon of lightimac256 is a glorious beacon of light
cRIO File Writing Problem
My team is experiencing problems trying to write files to the cRIO. I have examined the threads on CD, and noticed you have to use the function "Priv_SetWriteFileAllowed(1);" to allow writing to the cRIO flash memory. I call this function in our program while including <WPILib.h> and I get the error that it is an undeclared function call.
I am wondering if I am possibly not including the correct header file for that call, or if I even need to call that anymore to access the memory.
Thanks,
-Ian McInerney
Programmer, Team 2022
Unread 09-03-2010, 10:54
davidalln's Avatar
davidalln davidalln is offline
World's Worst Coder
AKA: David Allen
FRC #2415 (The Westminster Wiredcats)
davidalln is on a distinguished road
Send a message via AIM to davidalln
Re: cRIO File Writing Problem
I believe that Pirv_SetWriteFileAllowed(1) applies to images (I read that somewhere). I have written a Log class that successfully writes to the cRIO without the use of that function:
http://gist.github.com/296373
Also, this thread might be of use to you: http://www.chiefdelphi.com/forums/sh...ad.php?t=79548
SANTOSH ANDREW DECKER RICK WYNNIE SEAN DEREK MATT
(alamo (semis), p'tree (CHAMPS!), nc (CHAMPS!), newton (quarters))
Best four years of my life. Thanks to everyone who made it happen.
Unread 09-03-2010, 14:01
AKA: Ian McInerney
Upon further investigation of the image library files, I found that the prototype for that function was not in the headers anymore, so I had to add one.
This is what it looks like:
IMAQ_FUNC int Priv_SetWriteFileAllowed(UINT32 enable);
Thanks for all your help.
-Ian McInerney
Team 3132 - Sample code for writing to a file on the cRIO SteveGarward C/C++ 0 05-02-2010 07:26
Data File Writing ... cRIO vs. Driver Station Ziaholic NI LabVIEW 3 31-01-2010 15:20
Writing to DriverStation cRio screen alexjplant NI LabVIEW 2 17-01-2009 10:59
Reading binary data from a file and writing it in VB complete Programming 1 02-01-2006 21:21
Problem with reading and writing EEPROM DKolberg Programming 4 16-03-2004 19:29
