Go to Post "Oh, the farmer and the cowhand can be friends, la la la..." - Andy Baker [more]
  #31   Spotlight this post!
Unread 09-03-2010, 11:16
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Re: Power Management Recommendation for driver stations
I can really see this becoming a problem in Atlanta. Teams leaving their pits after lunch to go to eliminations and not coming back for hours. And then for a select few moving on to Einstein. Yah, there are a few plugs available, but they will get a lot of use out there. Teams need to be wise about when to have it on and when to shut it off.
1058 PVC Pirates 2016 - xxxx
  #32   Spotlight this post!
Unread 09-03-2010, 17:16
Alex Dinsmoor's Avatar
Alex Dinsmoor Alex Dinsmoor is offline
Are our seeding points over 9000?
FRC #0201 (FEDS)
Alex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant future
Send a message via AIM to Alex Dinsmoor
Originally Posted by ebarker View Post
Ask the 'safety captain' to cite the hazard !
If you have a UL approved inverter using the same Anderson connectors in the KOP using properly insulated wire ?!?! then they need to cite the hazard. Ask for the lead safety person.
Well when they yelled at us they said something along the lines of "Batteries are only to power robots, etc, etc" They didn't talk to me, but that's what I got out of it from overhearing them.
And we wern't which may have been the problem (but that still didn't justify their reasoning)... We were using insulated clips on the battery. We may make an Anderson connector one for the future competitions!
'08, '09, '10
4 Years | 14 Competitions | 194 Matches | 119 Wins | 77 Losses | 2 Silver | 1 Gold
  #33   Spotlight this post!
Unread 09-03-2010, 18:03
I might have backed them up on that decision. The power contained in one of our batteries is capable of sever damage if misused.
  #34   Spotlight this post!
Unread 09-03-2010, 18:40
Electrical Engineer
Rookie Year: 1995
I am an advocate for using an automotive DC/AC converter but do it safely.
Any good auto parts store will sell in-line maxi-fuse holders to put just after the battery. Good, solid, well insulated connections and some planning should placate the safety police.
JMHO,
Mike
Mike Betts
As easy as 355/113...
  #35   Spotlight this post!
Unread 09-03-2010, 19:53
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
Job #1 is Safety - get rid of alligator clips. I'd back up the safety guys if you didn't have Anderson connectors on the inverter.
Ed Barker
  #36   Spotlight this post!
Unread 09-03-2010, 21:29
Pausert Pausert is offline
FRC #1727 (REX)
Pausert is an unknown quantity at this point
REX has used the inverter solution for the past several years. Previously it let us do functionality checks in queu, but now we use it to top off the Classmate. We've used robot batteries with no problems, but occasionally we'll bring some much larger batteries that we bought for the purpose.
  #37   Spotlight this post!
Unread 10-03-2010, 18:48
AKA: Dr. Brooks
no team (WRRF)
PowerStream has a line of dc-dc converters
for those who don't want to run inverters.
www.powerstream.com
Model ED1060-20V-5.5-2.1 appears
to be a match for the classmate.
  #38   Spotlight this post!
Unread 11-03-2010, 00:45
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
This was a huge problem for us in SD in eliminations.
Our team borrowed a charged one from another team, but that in itself along with worrying about winning matches drove us nuts!!
I was going to post on Q&A.
I hope the GDC/FIRST instructs regionals to provide the power needed for classmate plugin or adaptor at the stations. It seems the easiest to address instead of asking all these teams to buy/make an adaptor for them.
  #39   Spotlight this post!
Unread 11-03-2010, 23:57
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
For teams currently at this week's regionals, is there any power present at the drivers station? I'd kind of like to know if this is something they might implement, before I spend the time and money on my own solution.
  #40   Spotlight this post!
Unread 12-03-2010, 07:33
No power at the WPI driver stations yesterday.
  #41   Spotlight this post!
Unread 12-03-2010, 09:50
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Just for some more ideas we use one of these (or its smaller cousin)
apc universal laptop battery
this one too
Just do an online search for "universal laptop battery" and you will find many devices. The advantage of these is they're typically small enough to either fit under the netbook or right next to it. All day Saturday and part of Friday we ran one of these, kept it plugged right on sitting right next to the classmate. Once we got back to the pit we plugged the classmate charger into the battery.
  #42   Spotlight this post!
Unread 13-03-2010, 15:53
AKA: Dr. Brooks
no team (WRRF)
I ordered the unit noted below from PowerStream,
but they sent me model ED1075 (a more common unit)
instead. The hole for the center pin on this one
was 1.7mm and it is likely too small for the classmate.
If you order from these guys you need to call them and
make sure that they have what you need.
Eugene
www.powerstream.com
  #43   Spotlight this post!
Unread 14-03-2010, 15:37
Until we can convince the powers that be to provide Classmate power at the driver's station, teams who are not playing in the finals, may want to top off their Classmate batteries and offer them to teams who are playing in the finals. This is not the best solution but it will insure that finals teams can continue to control their robots.
Also, to any teams that are using the inverter/robot battery solution, I would like to recommend an inline fuse to protect the battery and inverter. These are available at automotive stores and a 20-40 amp breaker should do the trick. Please use the same wiring size vs fuse choice that is listed in the robot rules.
  #44   Spotlight this post!
Unread 14-03-2010, 16:35
The Lucas's Avatar
CaMOElot, it is a silly place
If you are using the PSoC board make sure to unplug it between matches, it's a real powerhog. At Chesapeake Regional, our Classmate was charged going into Elims. By SF 1-2 our Classmate battery was in the red and the PSoC was failing to connect (so we stopped using it). In SF 1-4 (a back to back match), the battery was very low and may have contributed to periodic network communication error. We would run for about 10sec then lose communication for about 2 sec (not sure the Classmate was the problem but since we didnt play a match afterward, it remains a possibility). Back in the pits the PSoc wouldn't work till I plugged the Classmate in. I couldn't reproduce the communication errors while tethered.
Robot Inspector
  #45   Spotlight this post!
Unread 21-03-2010, 18:08
Damaku250's Avatar
Damaku250 Damaku250 is offline
Electromechaneumatics guy
AKA: Craig Hoo
FRC #3161 (H.T. Tronic Titans)
Team Role: Electrical
Damaku250 is an unknown quantity at this point
One of our team members has an uninterruptable power source: http://www.tigerdirect.ca/applicatio...2224&CatId=234
Would we be able to use this on the field to power the laptop?
-Rookie All Star Award [WAT Regional 2010]
Electrical/Control systems, Mechanical and Pneumatics teams, Human player
Laptop recommendation for inventor/pro/e/etc Zyrano CAD 6 28-01-2010 23:20
"vertran" teams not getting the new driver stations?!?! BEEKMAN FRC Control System 6 06-11-2009 20:10
Power Driver Station with Serial pyr0b0y Technical Discussion 6 30-04-2009 19:53
Power for Driver Station mutantblond Technical Discussion 26 11-03-2009 01:20
Laptop for FRC Labview: Recommendation Wanted Foster National Instruments LabVIEW and Data Acquisition 2 22-11-2008 21:14
