Go to Post Dont give up, because that is when you lose what you have. FIRST is the best experience that I have had throughout my entire life and there is no way ANYONE can make me quit FIRST. - Arefin Bari [more]
Unread 09-03-2010, 15:42
Phoenix.14's Avatar
Phoenix.14 Phoenix.14 is offline
AKA: Thomas
FRC #1757 (The Wolverines)
Phoenix.14 is an unknown quantity at this point
Dashboard command line?
Ever since the latest DS update, the dashboard command line has vanished from our driver's station console. This is a problem, because our current dashboard isn't working well and we want to switch to another one, but I can't figure out how to do that anymore.
I was going to just rename the new dashboard the same as the old one, but one is a .vi and the other is a .exe, so it wouldn't work. Has anyone else encountered this or figured out a solution?
Unread 09-03-2010, 18:27
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Re: Dashboard command line?
When you build the EXE of your dashboard, move the files to Program Files/FRC PC Dashboard and replace the existing files with yours. Then your dashboard will replace the current one
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 10-03-2010, 11:09
With your new Dashboard you need to:
  1. right click on "Build Specifications" and choose New -> Application (EXE)
  2. The properties window will popup and you can
    • Set the path to C:\Program Files\FRC Dashboard
    • Change the name to Dashboard.exe
  3. Go to "Source Files" on the left listing
  4. Select "Dashboard Main.vi" and push the right arrow button beside "Startup VIs"
  5. Click OK to close the popup properties window
Now whenever you right-click on that new spec under Build Specifications and choose "Build", your new Dashboard will replace the existing Dashboard.
Double check that the new EXE ends up in the correct directory with the correct name, e.g., C:\Program Files\FRC Dashboard\Dashboard.exe
Unread 13-03-2010, 10:13
If you still have issues, it could be that the DS with the command line was used to change the command.
The command line is saved in the All Users account, My Documents, in the DS settings ini file. Sorry I can't give the exact path at the moment, but I think you'll find it. It is a simple text file, and one of the settings is the command line. If you delete a line, it will be restored to the factory default during the next run.
Greg McKaskle
command listfor c??? jfrank Programming 12 22-01-2008 20:16
assembly command tseres Programming 3 18-01-2008 08:13
Command and Conquer captainking Games/Trivia 1 08-01-2008 23:20
Labview Dashboard and updated IFI dashboard spec Joe Ross LabView and Data Acquisition 1 04-04-2006 02:04
TAB command in Pbasic virusmirusne Programming 11 25-01-2003 02:51
