Go to Post The proper way to advance forward is by bringing the bottom up, not by limiting how high the top can fly. - artdutra04 [more]
Unread 09-03-2010, 16:28
Yuan Xue Lim's Avatar
Yuan Xue Lim Yuan Xue Lim is offline
Electrical Programmer
FRC #3017 (Project Genesis)
Yuan Xue Lim is an unknown quantity at this point
Send a message via AIM to Yuan Xue Lim
Leaking air
We are having problem with our pneumatics system. We are trying to have our system to stay at 60psi for the working pressure. However, it is gradually leaking air. It used to be slower but right now it is at a faster rate.
We try check it using soapy water but we didn't see any leaks(bubbly).
Is it possible that it leaks because we don't have the storage tanks?
[font="Fixedsys"][b]We Don't Hope We will.
Unread 09-03-2010, 16:33
Matt Howard's Avatar
Matt Howard Matt Howard is offline
Submarine Sailor
FRC #1622 (Spyder)
Matt Howard has a spectacular aura aboutMatt Howard has a spectacular aura aboutMatt Howard has a spectacular aura about
Re: Leaking air
A leak is a leak, no matter how the system is plumbed. Check the Regulator, we've had one fail on us every season.
-2010 Las Vegas Regional Judges Award
-2010 Las Vegas Regional Safety Award
-2010 San Diego Regional GM Industrial Design Award
-2010 San Diego Regional Excellence in Design Award
Unread 09-03-2010, 16:41
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: Leaking air
Check both ports on the compressor. For the last few years the screw in there has not had any threadlocker/teflon tape and the casting has leaked a little.
___________________
- Tennyson, Ulysses
Unread 09-03-2010, 16:42
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Re: Leaking air
Without storage tanks, your 120psi volume is very small. With such a system even very small leaks will run you out of air fairly quickly. That being said, there is no reason why you shouldn't have a tight pneumatic system. Check everything that sees pressure. Not just the joints. The gages can leak, the relief valve can leak, the regulator can leak, the fittings can leak, the solenoids can leak. Systematically and throughly check one component at a time with soap bubbles, because you surely have a leak. While in the Navy, we had an apparent leak in one of our systems and it took me 7 months to track it down. Just because you haven't found it, doesn't mean it doesn't exist.
I don't need a signature.
Unread 09-03-2010, 19:27
Re: Leaking air
Also, make sure the ends of the pneumatic tube were cut square. I've caught a couple leaks because someone cut the end at an angle and it could not go into the fitting far enough to make a good seal.
Unread 09-03-2010, 19:40
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: Leaking air
Are you being generous enough with the teflon tape at the thread sealings? We taped the crap out of our pneumatic system, and combined with checking for flat cuts, our simple pneumatic system with a compressor, 1 air tank, and 2 solenoids with 3 pistons (kicker clutch and shifters) can hold the tank above 100psi overnight.
Kettering Motorsports
Unread 09-03-2010, 19:50
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
Re: Leaking air
No storage volume (tanks) is your primary problem. Without more volume, almost no system could hold full pressure for long even if well assembled. The smallest leak will cause pressure loss fairly quickly. If your robot can accomodate tanks, add them. They are a common component of a system for good reason.
ttldomination's Avatar
Sunny
Re: Leaking air
You wanna check your tubing first. I would recommend using smoke over water.
If it continues to leak, I recommend having some fun with duct tape, which is legal this year.
1648: 2013-2014
5283: 2015
Unread 09-03-2010, 20:05
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Leaking air
There's still the whole "Too much of a good thing" problem. It's conceivable to put so much teflon on a fitting that you can't even thread it. It also makes it harder to tighten up fittings and increases the risk of getting shreds of teflon in your system. Not to mention the nightmare of having to clean it off the fitting if you ever have to disassemble things.
We usually don't bother with more than 2-3 wraps of teflon on my team or at my company for these reasons. If you properly tighten the fittings, this is more than enough to get a good seal, and little enough to not cause you problems.
Unread 09-03-2010, 20:47
jspatz1's Avatar
AKA: Jeff
Re: Leaking air
Too much tape can also cause problems with fragments getting into the air flow and reaching the solenoid valve spools, where they can jam spools and cause a failure. A couple of wraps is sufficient. Just assemble your system tightly and with care.
Unread 09-03-2010, 21:05
apalrd's Avatar
More Torque!
VRC #3333
Re: Leaking air
by "tape the crap out of it" I mean "tape the crap out of it until there is plenty but not too much". We don't have more than 3 wraps on any one fitting.
FESTO Leaking Air sbelding Pneumatics 2 20-02-2010 16:47
Leaking Solenoid? ygd Pneumatics 5 03-02-2010 00:31
Microwave leaking? sanddrag Electrical 8 30-08-2006 20:06
Are we allowed to use a Bimba air-to-air booster? Alex Minot Pneumatics 1 20-02-2005 22:32
Leaking piston? Bill Becker Pneumatics 6 23-03-2004 18:10
