Go to Post Doughnuts would probably be a pretty good alternative to churros. However, that could be open to debate. - Calvin Hartley [more]
Unread 09-03-2010, 23:31
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Neat demonstration of proportional and PID control systems
A very nice demo that shows the significant improvements to be had using a PID control vs. a simple P control via Makezine's blog.
For your consideration when planning your own robot control system
Cheers,
Joe J.
Team #88, TJ2
Unread 10-03-2010, 00:08
Re: Neat demonstration of proportional and PID control systems
Cheers,
Joe J.
If only I could tune ours half as well as that guy.
Unread 10-03-2010, 01:35
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Don't sell yourself short - I've seen some pretty amazing PID applications in FIRST. Remember that response is both torque and mass dependent, and as far as that goes he has a huge advantage (high torque for very low mass) that allows his motions to be much quicker than ours.
Unread 10-03-2010, 18:23
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Not wanting to be one who splits hair..... but in this case I will.
IMHO, his tuning needs a bit more work. There is still a bit of overshoot or ringing in it's motion. I'll bet it can be tuned even better.
Unread 14-03-2010, 16:45
JGurnow's Avatar
JGurnow JGurnow is offline
FRC #0217 (The Thunder Chickens)
JGurnow is on a distinguished road
P and I aren't that hard to implement with some testing. D is hard to wrap your mind around a lot of the times as a newer programmer.
P helps make sure you get near your target, and decelerate as it approaches it
I makes sure you reach your target but overshots and undershots if gains are incorrect.
D is hard to explain.
Unread 14-03-2010, 17:40
In a nutshell:
P gives you fast dynamic response.
I gives you steady-state accuracy.
D allows P to be set to a higher gain for even better dynamic response. (D can remove some of the overshoot caused by high P values).
Unread 14-03-2010, 17:43
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
Think "D is for damping". It is kind of like software friction. It always acts in the opposite direction of motion, and is proportional to how fast the object is moving. The faster the object moves, the more the D control tries to slow it down. This helps to settle out oscillation and remove overshoot.
Unread 14-03-2010, 17:50
Yup. That's why you can crank up P if you add some D. Thereby getting even better dynamic response.
Unread 16-03-2010, 03:41
Mark Sheridan's Avatar
Mark Sheridan Mark Sheridan is offline
Head Mentor
FRC #3476 (Code Orange)
Mark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond repute
I love PID controls. Back in college, I had a project where I balanced a vertical bar mounted to a bearing on a swinging arm (like balancing a ruler in the palm of your hand). You could hit that bar all day and it would never fall over. Too bad my students were not interested by my retellings of that project. Maybe this video will spark their interest and show the benefits of PID controls (especially in the context of autonomous drivetrains). Thanks for sharing!
Team 3476| Mentor| 2014 - Current
Team 3309| Mentor| 2011 - 2016
Team 766 | Mentor| 2006 - 2011 | Alumnus | 2002-2005
Unread 16-03-2010, 09:50
Unstable equilibrium. Some high-performance military aircraft today are aerodynamically unstable, and are able to fly only because high-speed computers control the flight surfaces. Computer goes down, aircraft goes down.
Unread 16-03-2010, 10:24
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
What I hate about PID control is that it allows the guess and check method of control without really coming up with a conclusion of why you tried certain values. It completely eliminates the analysis portion of closed loop feedback -- analysis that could fundamentally improve even the mechanical side of the design.
Aside from that fundamental flaw, yes PID is good enough for FRC. Who has the time to truly model a subsystem in FRC anyways?
GitHub
Unread 16-03-2010, 11:06
While you can tune PID controllers by trial and error, there are certainly plenty of analysis methods to make your tuning more efficient and at least get you in the right ballpark.
As for modeling subsystems, we do it quite often and find it very helpful.
I haven't yet had the fortitude to do a real full-state feedback controller on a FIRST robot YET, but I see it coming. I should have proposed it this year.
Unread 16-03-2010, 22:18
There are tried-and-true methods of tuning PID controllers, based on theory and years of experience, that I would not characterize as "guess and check". If the P, I, and D are tuned in the proper order, with the gain in each step being adjusted to obtain specific dynamic behaviors, a near-optimum solution can often be reached in only one or two passes.
PID Control Geek 2.0 Programming 16 12-01-2010 21:10
LabVIEW Training and new control system demonstration 10/17-10/19 in Frazier Park, CA Joe Ross NI LabVIEW 0 25-09-2008 13:25
PID Control John Gutmann Programming 12 15-04-2007 18:52
PID Control Chris Bright Programming 9 26-03-2005 19:44
Proportional Control ShadowFlame Programming 0 14-02-2004 11:53
