Go to Post FIRST is not a destination, its not the reward, its the slingshot that will launch you from where you are, to where you can be. - KenWittlief [more]
  #106   Spotlight this post!
Unread 07-03-2010, 21:17
agentmicrofishy's Avatar
agentmicrofishy agentmicrofishy is offline
FRC #3021 (The Caiman Agents)
Team Role: Marketing
agentmicrofishy is an unknown quantity at this point
Re: Should I buy a Mac or a PC?
Here's the analogy I like to use:
Power -------> simplicity
It's an inverse relationship between power and simplicity. As the power goes down, simplicity goes up.
  #107   Spotlight this post!
Unread 09-03-2010, 16:50
CraigHickman
Posts: n/a
So you've got a full UNIX shell underneath the hood of your Windows machine? You can simply enable SVN to track your code, and host the repository on an apache server that's already installed? How about a native scripting language for automating tasks? Can you set Cron jobs for little things that you do daily? Or does Windows not do that?
My point is this: It's not always as linear as you make it out to be. Yes, OSX has a "simple" UI, but under the hood it will always out-pace Windows. Until on Windows I can install git and grab the latest builds automatically for an experimental web browser without needing to sacrifice a child every time, I won't move back to it.
  #108   Spotlight this post!
Unread 10-03-2010, 11:38
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Wake Up Get Up Get Out There
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
Originally Posted by [TBT] Phoenix View Post
BUY MAC NOW!!!!!
This is as helpful and annoying as the Mac detractors.
BTW, 5 year old PB G4 still runs great, but I've upgraded to a 13" MBP. Can't say the same thing about a lot of my friend's PCs' they bought for the same price (or more).
  #109   Spotlight this post!
Unread 10-03-2010, 12:33
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
My 5 yr old P4 still works great, but I replaced the motherboard a year ago with a core 2 duo, which is really easy to do using a 10 year old ATX case.
I borrowed my brother's 3 yr old Mini, he gave up on it...I'm trying to find the attraction, haven't yet, I'll keep playing with it though.
  #110   Spotlight this post!
Unread 10-03-2010, 12:37
CraigHickman
Posts: n/a
Once you start playing with Automater and AppleScript, a whole world of other uses opens up.
Also, Expose and Spaces make it impossible for me to go back to a Windows machine. It's just too darn convenient to use.
  #111   Spotlight this post!
Unread 10-03-2010, 16:03
Joe Matt's Avatar
Congrats on comparing an old top of the line system with a bottom of the line. Want a biased cookie?
  #112   Spotlight this post!
Unread 10-03-2010, 16:44
MrForbes's Avatar
AKA: Jim
I'm not sure what you mean by that...I have a rather low end PC (it was low end when I moved up to a P4, and again when I moved up to a C2D, both processors were just a bit over $100), and the Mac Mini was bottom of the line.
Mac doesn't have much in the way of "low end", especially in the laptop department, when compared to PC stuff.
  #113   Spotlight this post!
Unread 24-03-2010, 02:42
Mesehibestops Mesehibestops is offline
Junior Member
Mesehibestops is an unknown quantity at this point
Personally I didnt but If I am thinking to try also. Digg is supposed to bring good traffic but only if you promote something valuable and new there NOT your MFA site. BTW where do you think to buy diggs?
Anyway this is counted as unethical marketing...
  #114   Spotlight this post!
Unread 24-03-2010, 02:54
I have a Toshiba desktop that must be 10 years old. Except for replacing a hard drive in about 2005 it's been flawless. It's too slow to really run anything modern, but it still works. The Dell desktop that replaced it is about six years old and is still running as a file server. Build quality is not a unique Apple feature.
  #115   Spotlight this post!
Unread 24-03-2010, 13:47
robself705's Avatar
robself705 robself705 is offline
Team Leader / Mechanical
AKA: Rob Self
FRC #0706 (Cyberhawks)
robself705 is a name known to allrobself705 is a name known to allrobself705 is a name known to allrobself705 is a name known to allrobself705 is a name known to allrobself705 is a name known to all
Originally Posted by whytheheckme View Post
Hmm... I'm not too sure how strongly I feel about my OPERATING SYSTEM using a gig of my RAM.....
In all honesty, t41w4ne5ef0b, I have used the Windows 7 beta and RC - It's just as bad as Vista, and in many ways, worse. It uses more RAM, has many of the same driver issues, has locked up on me numerous times, and things just.... Fail to work! Applications, hardware, it's a disaster. IF you decide to go with a Windows-based laptop (I hate to call them PCs.... All computers are PCs) please use Windows XP, SP2 (SP3 is garbage, and breaks way more things than it fixes. In my opinion, SP3 is a ploy to get you to upgrade to Vista after your machine stops working from the broken update.)
There is a reason it uses so much RAM, it actively loads frequently used programs into your memory so your computer runs FASTER. Obviously if you need all your RAM for a program it frees up all the space you need. Microsoft was right in thinking that people don't need 3gb of free RAM. Why not use that RAM to make programs boot faster? Sounds good to me. Also I have Windows 7 Ultimate 64bit and it is AMAZING. I have had it for 5 months and it hasn't crashed EVER. NOT ONCE. Never have I gotten a virus yet either. It is so fast and is compatible with much more software than MACS are. If you want a nice looking computer with VERY easy to use applications but not much expandibility, get a MAC. If you want a computer that will work with any application you could ever want to use get a PC.
Rob Self-
Cyberhawks Team 706
Hartland, WI
Our breakaway bot in action (13-3-1): Team 706 in action
  #116   Spotlight this post!
Unread 24-03-2010, 16:36
CraigHickman
Posts: n/a
Find me a type of application that you believe to be Windows only and I will find you a Mac equivalent. Hands down. Due to the UNIX shell, Mac can run any Linux compatible software (albeit with some serious work for some...), something that Windows will never achieve.
So tell me this: How do you run cron jobs on your Windows machine? How do you set up git or svn functionality without some bloated third party piece of software? The list goes on.
  #117   Spotlight this post!
Unread 27-03-2010, 16:25
Chickenonastick's Avatar
Chickenonastick Chickenonastick is offline
Not a kebab
FRC #3256 (WarriorBorgs)
Chickenonastick is on a distinguished road
If the Mini is exactly 3 years old, the two systems (an old system w/ an upgraded C2D proc) and the Mac Mini should be comparable in terms of performance.
This has probably been mentioned numerous times, but I personally find Macintosh computers severely overpriced for the hardware being purchased.
For desktops, a comparable system being purchased part by part is often 25% cheaper than the macs' components altogether. Of course, it wouldn't have the stylish design of a mac or OSX 10, but it will often have equal or greater processing power (not to mention your choice of a dedicated graphics card )
Furthermore, if you like OSX that much, you could purchase the OS and install it onto your system (although the legality of that action is questionable)
  #118   Spotlight this post!
Unread 27-03-2010, 16:37
Chris is me's Avatar
AKA: Pinecone
The main thing here is Apple's insistence on not refreshing its own products. When they launched, the Mac Pro was pretty notable for being the most economical option for a high end desktop PC, and the Macbook Pro wasn't too far behind. Years later, they've upgraded slower than the rest of the PC world.
  #119   Spotlight this post!
Unread 27-03-2010, 19:46
CraigHickman
Posts: n/a
...And yet their sales are STILL crushing every other hardware manufacturer. Huh.
  #120   Spotlight this post!
Unread 27-03-2010, 19:52
AKA: Pinecone
http://www.outlookseries.com/N4/Infr...hipments. htm
The first chart doesn't include Apple estimates, but the chart listing 4Q09 estimates clearly shows them in fourth, if that's how you roll.
Where to buy Buy FRP in AZ? falconmaster General Forum 9 05-01-2009 16:36
Mac users: Do you buy AppleCare? Billfred Chit-Chat 16 31-07-2007 14:14
How many extra batteries should you bring, and where can you buy more? haverfordfords Electrical 6 08-02-2005 22:01
What reciever should I buy for my home stereo? Ben Lauer Chit-Chat 4 19-12-2004 23:51
Santa and Will Ferral want you to buy a mac MattK Chit-Chat 3 26-11-2002 17:29
