Go to Post Putting 2 and 2 together, and then mixing them back up for someone else to try and get 4 in a different way is just plain fun. - Elgin Clock [more]
Unread 07-02-2009, 11:01
Comatose Comatose is offline
AKA: Lead Student Programmer
FRC #0135 (Penn Robotics)
Comatose is an unknown quantity at this point
View block diagram of code that has been deployed as run on start up?
Is there a way to view code and its block diagram while it runs as startup on the cRIO, just like when you deploy it to RAM? I've seen the dashboard VI, and was wondering if that had anything to do with it.
Thanks,
Comatose
Unread 10-03-2010, 11:52
randalcr's Avatar
randalcr randalcr is offline
Programming Mentor
AKA: Chance Randall
FRC #0476 (Wildcats)
randalcr is an unknown quantity at this point
Re: View block diagram of code that has been deployed as run on start up?
what you can do is run the code off one laptop and then control the bot off of the DS while your connected to your router.
Unread 10-03-2010, 12:21
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
I don't have the cRIO in front of me, but you should be able to connect to code already running on the cRIO to debug it. However, the code in your project MUST be the same at the code in the cRIO, or it won't work. A quick search leads me to these steps:
1. Power up your cRIO/Robot.
2. Open the correct project with your code in it.
3. Open up Robot Main.vi
4. Select Operate->Debug Application or Shared Library.
5. Type in your robot's IP address and click "Refresh"
6. Select the application to debug, which should be Robot Main.vi
7. Click Connect
I think that will work, but I don't have a system to test it on, and I'm not a true Labview guru. I got all that info from this NI page:
http://zone.ni.com/reference/en-XX/h...bug_apps_dlls/
If one of the NI guys comes along and declares the above completely wrong then my apologies for leading you astray.
Unread 10-03-2010, 12:50
I spent about 2 seconds trying to get debugging to work on an already deployed program last year, following the steps that Kevin posted. It didn't work, and I didn't spend any additional time trying to figure out why. It's quite likely I did something wrong.
Ever been asked a simple question, that could have been answered with a search? Kingofl337 Chit-Chat 5 21-11-2008 08:35
Vex start up code run PWM outputs without Rx intellec7 Programming 3 05-05-2006 23:29
Update 19 has been released dachickindapit General Forum 11 13-04-2005 18:08
Nationals Has Been Cancelled!! 157#1Driver Rumor Mill 13 01-04-2003 20:56
Has 2vs2 been revealed? jrukes Rumor Mill 15 23-10-2001 22:40
