Re: Camera live feed not working
The first update had an issue that kept it from overwriting the older dashboard app with the newer one, and the effective workaround was to run it once to uninstall everything then run it again to reinstall the proper version of everything. The current update does not have that problem, and the workaround is no longer necessary.
double-check the physical wiring of the camera
Also, are you letting the system have a bit of time to load? The camera loads later than the cRIO code so there is a delay before images are sent. What is the color of the ring around the camera lens while the robot is on? |
Just want to add that make sure the ethernet cable is a cross-over cable.
AxisCamera &camera = AxisCamera::GetInstance();
camera.WriteResolution(AxisCamera::kResolution_320x240);
camera.WriteCompression(20);
camera.WriteBrightness(0);
| 2010 FRC Camera Live Feed Lag | ideasrule | Programming | 23 | 11-02-2010 02:33 |
| Yet Another Axis Camera Live Feed Issue | z2daj | FRC Control System | 2 | 24-01-2010 13:47 |
| Live Feed with Axis Camera | CHSboy | Programming | 6 | 24-03-2009 14:43 |
| 2009 - Live camera feed to drivers during a match? | Travis Hoffman | Rules/Strategy | 23 | 21-01-2009 17:43 |
| Getting Live Feed from Axis Camera in Windriver | Inoperational | C/C++ | 8 | 15-01-2009 01:21 |
