Go to Post Then you might have a 1902 (oink oink BOOM) which could result in a 418 (Purple Haze). - JaneYoung [more]
  #121   Spotlight this post!
Unread 10-03-2010, 13:22
pathew100 pathew100 is offline
AKA: Pat Murphy
FRC #0862 (Lightning Robtics)
pathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud of
Send a message via AIM to pathew100
Re: Team update 16
Originally Posted by martin417 View Post
I was surprised at the <G46> penalties, not because the penalties were called, but because teams did not design their bot to prevent it. How hard is it to design a bot that doesn't allow a 3" penetration? Did teams not do testing prior to ship? The rule existed from the beginning. I hate to put blame on teams, but that was an easy thing to fix.
Before I get flamed, I am not talking about getting forced over a ball on a hump, or something un-avoidable. But if the ball can get under your bot just driving around, you need to make a change. You should have tested for this possibility. The rules were clear.
Obviously teams need to prevent the ball from going under completely, and that is still a penalty.
The situation that U16 addresses regarding <G46> is a 'transient'-type ball incursion. This happened many times and was the cause of most of the <G46> penalties last week (that I saw).
For example, when a robot drives up to a ball and a traction wheel grabs it and they 'ride up' on it for a a second and then immediately back down and off the ball. Or a roller bar grabs a ball and starts to suck the ball under but they back off immediately.
  #122   Spotlight this post!
Unread 10-03-2010, 13:41
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
Re: Team update 16
I think Team Update 16 was a result of the Referees doing an excellent job at week 1 regionals. They called the penalties by the book at least 95%+ of the time and because of that the GDC was able to make appropriate rule changes.
Also of note, I hope Bill's Blog updates to give us more insight to the changes.
Good job GDC, I support these changes, despite being unfair to week 1 regionals (hindsight is always 20/20), I think this will improve the spirit of the game a great deal.
  #123   Spotlight this post!
Unread 10-03-2010, 14:15
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
Re: Team update 16
Originally Posted by JesseK View Post
... Even so, we only ever got one 3" incursion penalty and it was because we went head-to-head with another robot and they pushed their possessed ball under our robot.
Interesting that you got a penalty for that. Our assesment of the rules would indicate that there should have not been a penalty under <G13>:
<G13> Causing PENALTIES – The actions of an ALLIANCE shall not cause an opposing ALLIANCE to violate a rule and thus incur PENALTIES. Any rule violations committed by the affected ALLIANCE shall be excused, and no PENALTIES will be assigned.
Did you protest the call?
  #124   Spotlight this post!
Unread 10-03-2010, 14:22
Re: Team update 16
Chuck,
Don't forget this...
<R19> ROBOTS must be designed so that in normal operation BALLS cannot extend more than 3 inches inside
a) the FRAME PERIMETER below the level of the BUMPER ZONE (see Figure 8-5),
b) a MECHANISM or feature designed or used to deflect BALLS in a controlled manner that is above the level of the BUMPER ZONE.
R19 remains unchanged and may have played into the decision.
  #125   Spotlight this post!
Unread 10-03-2010, 14:30
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Team update 16
No, it was deemed insignificant at the time considering it was Saturday and it was only our 2nd penalty total (the first being incidental contact with a flipped robot within the grace period).
GitHub
  #126   Spotlight this post!
Unread 10-03-2010, 14:32
Sumathi's Avatar
Sumathi Sumathi is offline
FRC #2410 (The Metal Mustangs)
Sumathi is an unknown quantity at this point
Re: Team update 16
So they are still using the coopertition ranking system to award points, but the winner gets 5 extra points? Correct me if I am wrong.
  #127   Spotlight this post!
Unread 10-03-2010, 14:40
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Team update 16
Originally Posted by jspatz1 View Post
It could be argued that for most robots, driving over the ball was not really an incursion violation anyway. If you think of the bottom of the robot in the same terms as the top of the robot, the ball could pass under the bottom without actually penetrating the frame volume by 3", just as it can roll across the top without doing so.
The bottom of the robot is not the same as the top, in terms of <R19>.
The rule is not that the ball cannot come into a verticle projection of the frame perimeter
Below the bumper zone, that is actually the rule. <R19> spells this all out.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
  #128   Spotlight this post!
Unread 10-03-2010, 15:06
Re: Team update 16
Chuck,
Absolutely, which begs the question is this an inspection issue or a referee issue? As an inspector we required the robots to have some reasonable protection on the top and sides such that the balls couldn’t enter the robot more than 3”. We required several teams to add some sort of netting, Lexan, or other cover on their tops and/or bars or something on the lower parts of the sides so that the balls didn’t have a reasonable chance of entering the robot by more than 3”. We assumed this to be the intent of <R19>. However, we didn’t require all the bots to be solid on the bottom as this would inhibit going over the bumps in most cases. If you incurred a penalty by riding up on the ball and trapping it under/inside your robot the inspectors considered that to be a field issue for the refs to deal with. I guess I am wondering what "normal operation" means? <R19> would seem to be an inspection issue as it is a robot rule not a game rule. If you designed your robot to go over the bump then is that not "normal operation"? If in "normal operation" a ball can go under and end up trapped inside your robot is this something the inspectors should fail or is this something to be left to the refs to penalize on the field?
  #129   Spotlight this post!
Unread 10-03-2010, 15:14
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
Re: Team update 16
I stand corrected.
  #130   Spotlight this post!
Unread 10-03-2010, 16:04
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
Re: Team update 16
Even with an army of brainstorming sessions, going over a bump onto a ball resulting in a penalty never even crossed our minds. We're not geniuses, but we do consider ourselves to be "smart". It's simply impossible to play out every possible scenario beforehand, thus designing to be adaptable was higher on our priority list than designing to be perfect. I'm sure there were many other teams in the same boat. Even so, we only ever got one 3" incursion penalty and it was because we went head-to-head with another robot and they pushed their possessed ball under our robot.
As I said in my post, I was not talking about going over a bump onto the ball. Most of the penalties I saw at Peachtree were caused by robots in the open field trying to push a single ball all by themselves, and driving over that ball. This could be tested with a $10.00 soccer ball in 5 minutes of testing prior to ship. I know we did a lot of such testing to insure that it couldn't happen to us.
Former Mentor Team 1771
Former mentor Team 4509
  #131   Spotlight this post!
Unread 10-03-2010, 19:06
anyheck anyheck is offline
FRC #2242 (Cougars)
anyheck is on a distinguished road
Re: Team update 16
Changing the rules in the middle of the season = Fundamental FAIL.
  #132   Spotlight this post!
Unread 10-03-2010, 19:26
jspatz1's Avatar
AKA: Jeff
Re: Team update 16
It is the beginning of the season, not the middle. NOT changing the rules after flaws are uncovered would have been a fundamental fail.
  #133   Spotlight this post!
Unread 10-03-2010, 19:31
FRC #2242 (Cougars)
Re: Team update 16
The beginning of the season was more than 6 weeks ago.
  #134   Spotlight this post!
Unread 10-03-2010, 21:55
BIGWILLI2081's Avatar
BIGWILLI2081 BIGWILLI2081 is offline
FRC #2081 (Icarus)
BIGWILLI2081 is a glorious beacon of lightBIGWILLI2081 is a glorious beacon of lightBIGWILLI2081 is a glorious beacon of lightBIGWILLI2081 is a glorious beacon of lightBIGWILLI2081 is a glorious beacon of lightBIGWILLI2081 is a glorious beacon of light
Re: Team update 16
When were they to know some of the rules were not the best? Before the regionals started? They had to observe it before they could change it. Although, I do agree the seeding point system was not the best to begin with, it just took some examples (and complaining) before the GDC realized they had to do something to make it better. Unfortunately for week 1 teams, they were the guinea pigs. It's better they change them now than never. I give props to the GDC for fixing the rules.
  #135   Spotlight this post!
Unread 10-03-2010, 22:02
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Re: Team update 16
Sounds better if you call them beta testers.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Team Update 4 GaryVoshol Rules/Strategy 4 22-01-2010 21:45
Team Update #7 EricH Rules/Strategy 21 28-01-2009 01:46
Team Update 6 Joe Ross Rules/Strategy 12 24-01-2009 03:23
Team Update # 2 Brett W General Forum 1 09-01-2003 20:47
