Go to Post push for what you think is right... just do it in the right way - Andy Baker [more]
Unread 10-09-2002, 18:50
RobDeCotiis RobDeCotiis is offline
FRC #1660
RobDeCotiis can only hope to improve
Send a message via AIM to RobDeCotiis
Pump
Anyone know how long it takes for the pump to fill the 2 canisters with air? and what psi are we allowed to fill the containers to? i know we're only allowed to work with 60 psi but are we allowed to store 120 or something? but the most important thing is how long does it take to fill the 2 containers to 60 psi?
Thanks
Rob - anxiously awaiting the pump he's taking home from school to start figuring out next year's stuff
Unread 10-09-2002, 21:28
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer & Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
you mean the 2 cylinders, the compressor supplied by first. if your just talk ing about the pump going to the cyclinders it should not take to long. but if you have like cylinders and canistors and pum (neva mind a full pneumatic system) give or take depending on a leak about 2 minutes pending what the length of the tubing is it could be more or less time. if u can explain in detail how the system will be hooked up i might be able to give you a better estimate. i think 2 minutes or less though. if the tube is long then it will take longer sry dude w/o more info can't be too much help.
Unread 10-09-2002, 21:31
Ashley Weed Ashley Weed is offline
Rookie Year: 1995
Ashley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond repute
If I am at all following you in your inquiry.... we always store air before entering the field. However after two attempts at the goals with each arm, you have to wait about 15 sec. before the tanks are refilled. evulish may be able to verify this more, and make sure I am talking about the same thing as you.
Unread 10-09-2002, 22:24
FRC #1660
ok sorry for confusing you guys.. how long do you estimate it would take the compressor to charge the air tanks with say 10 cubic inches of air at 60 psi.. what i'm saying is if i have a piston using 10 cubic inches per stroke @ 60 psi, how long is it gonna take the air tank to recharge to max capacity?(ie so i can do the next stroke with the same amount of air in the tanks)
Unread 11-09-2002, 03:56
The most accurate, practical and direct way to find out would be to use a stopwatch on the actual system. I found that we could go from about 60 psi to 110 psi in about 10-15 s (a timing loop in PBASIC was used), using a single small reservoir, 2 yrs ago, but longer with both reservoirs last year, using the high- and low- pressure switch pair.
Sometimes it took lomger - especially with a leaky actuator we had, that would pass air around the piston if it were not fully open or fully closed.
Unread 11-09-2002, 12:40
Warren Boudreau Warren Boudreau is offline
FRC #0180 (Team SPAM)
Warren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond repute
Let's back up a bit. The compressor will pressurize the air in the accumulators to about 120 psi. That air is then regulated down to 60 psi, the working pressure for the systems. So you don't lose 10 cubic inches of air in the acccumulators, you lose 5 cubic inches.
We found that it doesn't take long to replace the air used in one stroke of a cylinder. What takes most of the time going from 0 to 120 psi. 0 psi being ambient pressure, not a vacuum.
I recommend using the limit switches and the control system to control the pump. That way you can turn the pump off at 120 psi and turn it on again around 80 psi. That way, you will always have 60 psi air to work with.
I hope this helps.
Warren B
Pool Noodles. They're not just for bumpers anymore.
Unread 11-09-2002, 15:08
FRC #1660
ok, you're making it much clearer to me, but i still have a few questions. first of all, if i'm using 10 cubic inches of air per stroke @ 60 psi(5 cubic inches at 120), how long will it take the pump to restore that air pressure? also, does anyone know if we're allowed to splice control wires? like if we want to run 2 actuators at the EXACT same time, could we just splice the wires and do it that way? the code would have very slight differences in timing, and we want exact. are we allowed to do that, and would it work?
Unread 11-09-2002, 16:06
No need to splice wires. Just out a T in the air line coming out of the valve and drive both acuators with one valve.
Unless you are using the big actuators, the valves should handle it.
You can adjust the flow rates to each actuator by fiddling with the little knobs on the fittings on the cylinders.
As far as the time it takes to restore the air in the accumulators, you will have to run some tests. But my recommendation is to just set the pump up on the limit switches and let it cut on and off as needed. As long as the pressure in the accumulators stays above 60 psi, then your actuators will work at 60 psi. Did you know that you can reduce that 60 psi? If you don't need a lot of force (pressure*actuator area), you can run a lower pressure and use less air per stroke.
Can you give some specs on the actuators that you are using? Number of acuators, diameter, stroke, and actuation frequency (strokes per minute)?
Warren B
Unread 11-09-2002, 17:48
FRC #1660
Warren B
Unread 11-09-2002, 18:02
FRC #1660
oops lol sorry bout that i was reading it in the reply window, trying to figure out what i'm saying back, and i accidentally hit enter.. heh anyway, the system i'm thinking of right now is 2 pistons .75" diameter, 2" stroke, 60 psi. as for the strokes per minute, i'm not quite sure. i'd like to figure out the maximum number of strokes per minute, which is what i'm trying to do.. that's what the whole compressor question is about.. as for the t line, i never thought of that.. heh shows how dumb i am.. lol.. if i was doing that, i'd run the two air tanks in line, right? that way the pressure would always be the same for each piston(one thing i need), and they would both go off at the same time(another thing i need). so basically, how many times do you think i'd be able to use these pistons a minute(if i use both at the same time, i'm using 1.76 cubic inches of air @ 60 psi per stroke.
Depending on that number, i'll either use larger or smaller pistons, based on the number of strokes per minute we can get out of this compressor..
Rob
Unread 13-09-2002, 13:20
OK Rob,
I did a little research for you. The pump in the kit is a Thomas Industries model 405ADC38-12. It's flow capacity is as follows:
Pressure (PSI)..........Flow(CFM)
40............................0.50
60............................0.38
80............................0.33
100............................0.24
CFM is cubic feet per minute. I would use 80 psi as your nominal operating pressure.
I'll leave the math up to you. Or, in the words or your favorite teachers, "The exercise is left to the student."
Enjoy.
Warren B
Unread 13-09-2002, 15:21
FRC #1660
thank you so much.. this really helps a lot with my project
Unread 01-11-2002, 21:31
kmcclary's Avatar
kmcclary kmcclary is offline
Founder 830/1015;Mentor 66/470/1502
FRC #0470 (Alpha Omega Robotics)
Rookie Year: 1994
kmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond repute
Originally posted by Warren Boudreau
OK Rob,
Wait a sec... Something is not right here. Are you SURE that's the one we're using? (I don't have one here to check...) According to the specs at:
- http://www.thomaspumps.com/products/...log/select.pdf
and
- http://www.thomaspumps.com/pdf/standard_catalog.pdf
although many WOB-L (R) pumps CAN go to 150 PSI, the 405 series is limited to a maximum rating of 100 PSI!
We're running our systems at a max of 120 PSI. Are we really running them over spec?
BTW... Where'd you find the flow rates you're quoting? They aren't in either of the above files. Can you please post the URL for the doc?
Thanks!
- Keith
Keith McClary - Organizer/Mentor/Sponsor - Ann Arbor MI area FIRST teams
ACTI - Automation Computer Technologies, Inc. (Sponsoring FIRST teams since 2001!)
MI Robot Club (Trainer) / GO-Tech Maker's Club / RepRap-Michigan) / SEMI CNC Club
"Certifiably Insane": Started FIVE FRC teams & many robot clubs (so far)!
2002: 830 "Rat Pack" | 2003-5;14: 1015;1076 "Pi Hi Samurai" | 2005-6: 1549 "Washtenuts"/"Fire Traxx"
2005-(on): 1502 "Technical Difficulties" | 2006-(on): FIRST Volunteer!
2009-(on): 470 "Alpha Omega" | WAFL | Sponsor & "Floating Engineer" for MI Dist 13 (Washtenaw Cnty)
2011: 3638 "Tigertrons" | 2013-(on): 4395 "ViBots" | 2014-(on) 66 "Grizzlies"
"Home" Teams: 66, 470, 1076, 1502, 4395
Local FIRST alumni at or coming to Ann Arbor (UM/EMU/WCC/Cleary)?
...We Want YOU as a Mentor! Please email me for info!
Support CDF Reputation - If a posting helped, thank 'em with rep points!
"It must be FRC build season when your spouse and children become 'Action Items 8 & 9'..."
Pump operation before match Jeff Waegelin Pneumatics 19 29-04-2003 09:42
pneumatic wiring nick_champ_2 Electrical 3 23-02-2003 01:21
Can you stop a pneumatic pump at half shaft mjt902 Pneumatics 16 06-02-2003 11:58
Error found in programming for the pump and pressure switch sjharobotics Programming 4 06-02-2002 17:46
Pneumatics pump allowed on robot? bigqueue Pneumatics 5 06-01-2002 12:30
