Go to Post There's too much whining lately.. we need a hug forum - Gadget470 [more]
Unread 10-03-2010, 14:32
aechmtwash11 aechmtwash11 is offline
FRC #2783
aechmtwash11 is an unknown quantity at this point
Solenoid Wiring
Will Standard 3 wire PWM's fit into the solenoid breakout? If not what do you use to connect solenoids to the breakout? I just noticed that the solenoid breakout only has two connections, a ground and signal. I would check this myself but I'm not at our shop.
Unread 10-03-2010, 14:48
GearsOfFury's Avatar
GearsOfFury GearsOfFury is offline
Former guy that does stuff
AKA: Mark Anderson
GearsOfFury is a splendid one to beholdGearsOfFury is a splendid one to beholdGearsOfFury is a splendid one to beholdGearsOfFury is a splendid one to beholdGearsOfFury is a splendid one to beholdGearsOfFury is a splendid one to beholdGearsOfFury is a splendid one to beholdGearsOfFury is a splendid one to behold
Re: Solenoid Wiring
No, standard 3-wire PWM's will not fit into the solenoid breakout, at least not with the blue cover connected.
Our team stripped off the third (white) wire on our PWM's, took off the male end and spliced it with the solenoid wires, and cut off the plastic edge of the female end where the white wire normally would be. You have to be careful when doing this, to not crush the female connector end. You also have to make sure you get as much of the extra plastic connector off as possible, or it won't fit easily into the breakout.
Alternative would be to buy some 2-wire connectors (I don't know where to find such a thing), or remove the blue cover connector (you lose the retention functionality that the cover provides, however).
Unread 10-03-2010, 14:50
Re: Solenoid Wiring
There were cables with 2-pin connectors included in the Kit of Parts. See the top of page 12 in the KOP Checklist.
If you can't find yours, it is possible to carefully trim the third pin from a standard PWM cable and make it fit perfectly.
Unread 10-03-2010, 14:54
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Solenoid Wiring
As Alan mentioned, 5 of these were provided in the KOP (which should make 10 solenoid cables as you only need 1 end)
If you need more here is the source listed in the Where to Get More document from FIRST:
http://www.pccables.com/cgi-bin/orde...les.com&rcode=
Unread 10-03-2010, 14:55
AKA: Mark Anderson
Re: Solenoid Wiring
Interesting, I wonder where our electrical team put all those...!
And, easy to find spares: http://www.pccables.com/cgi-bin/orde...les.com&rcode=
Thanks!
Unread 10-03-2010, 17:25
The Engineer The Engineer is offline
FRC #2607
The Engineer is an unknown quantity at this point
Re: Solenoid Wiring
we just use female to female two pin PWMs on a double solonide
Unread 10-03-2010, 19:33
Rapt0r9's Avatar
Rapt0r9 Rapt0r9 is offline
AKA: Tyler
FRC #0747 (Flight Crew)
Rapt0r9 will become famous soon enoughRapt0r9 will become famous soon enough
Re: Solenoid Wiring
I'm going to second the double pin connectors. We cut up about four of them between wiring up the signal light and the solenoids. They really have no other use besides that (unless you are doing some fancy sensor work). A simple cut and splice will get you going in no time.
BS Information Technology - NJIT (2009 - )
Team 869 (2004 - 2008, 2011 -), Team 1811 (2010), Team 869 (2009), Team 613 (2009 - 2010)
"Nothing in this life worth having comes easy."
Solenoid Wiring and Compressor Help BurtGummer Electrical 16 17-02-2010 14:25
Wiring for FESTO solenoid S Godez Pneumatics 1 09-02-2009 13:02
Wiring Single Solenoid almsfan21 Pneumatics 14 24-01-2008 13:10
Double Solenoid Wiring blindguyinanorg Pneumatics 7 09-10-2004 23:55
Festo solenoid wiring? computhief263 Pneumatics 1 15-02-2004 12:25
