Go to Post make sure to make it look really cool, it makes it easier for teams to remember you, which comes in handy for alliance selections ;) - Holtzman [more]
Unread 09-03-2010, 23:10
Wheelmaster
Posts: n/a
pic: Team 1369's robot
Unread 09-03-2010, 23:11
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
Re: pic: Team 1369's robot
wow! that looks amazing, cant wait to see you guys in a few days
Florida is looking to have some of the best competition and some of the best looking robots
1592(Student and Mentor) 2007-Present
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
Unread 10-03-2010, 08:57
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
*cringe* I really hate to be a Debby Downer, but have you reviewed to FRAME PERIMETER rules yet? And the fact that you're not allowed to have anything extended outside your FRAME PERIMETER?
If your bumpers are mounting flat against that upper surface, then you have a bunch of bolt head and bearings sticking out of your FRAME PERIMETER down there at your wheel axles. Which is illegal and shouldn't pass inspection.
Yes, they're small and likely insignificant, but the rules are the rules. If you get a strict inspector, you won't pass with those bolt heads sticking out. I think your best option would be to use a shim under the backside of your bumpers to slightly increase the size of your FRAME PERIMETER to cover those bolt heads.
Again, it's a nifty design and I hate bearing bad news, but you should go to Florida prepared to make a modification to get yourself fully legal.
Unread 10-03-2010, 14:31
mathman05 mathman05 is offline
None #1308
mathman05 is an unknown quantity at this point
Thanks for reading the rules. However, you apparently did not read the Team Updates. Take a glance at Update #6 when you get a chance.
Unread 10-03-2010, 14:54
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
You shouild read this thread. Remember, the frame perimeter is defined as that area within the bumper zone.
http://www.chiefdelphi.com/forums/sh...ight=perimeter
Unread 10-03-2010, 15:08
Sorry, I probably should have updated my signature to reflect that I'm the Lead Robot Inspector for the Lone Star Regional. That's been corrected now. Moving on...
Yes, I've read Updates #1-#16. And the Robot Rules. Let me toss out a definition so that we're all clear on what we're talking about.
FRAME PERIMETER – the polygon defined by the outer-most set of exterior vertices on the ROBOT (without the BUMPERS attached) that are within the BUMPER ZONE. To determine the FRAME PERIMETER, wrap a piece of string around the ROBOT at the level of the BUMPER ZONE - the string describes this polygon. Note: to permit a simplified definition of the FRAME PERIMETER and encourage a tight, robust connection between the BUMPERS and the FRAME PERIMETER, minor protrusions such as bolt heads, fastener ends, rivets, etc are excluded from the determination of the FRAME PERIMETER.
This is the FRAME PERIMETER as defined in the latest Robot Rules, modified per Update #6, and emphasis mine. Per the bolded clause, the FRAME PERIMETER is only defined In the BUMPER ZONE. And fasteners and such are excluded from this definition. So on the above pictured robot, the frame perimeter is smack-dab against that nice flat black plate. It's not defined by any bolt heads in the bumper zone. I'm sure we agree so far.
Moving on, we have the pertinent rule enforcing the FRAME PERIMETER:
<R16> During normal operation no part of the ROBOT shall extend outside the vertical projection of the FRAME PERIMETER, except as permitted by Rule <G30>.
a) Exception: To facilitate a tight, robust connection between the BUMPERS and the FRAME PERIMETER, minor protrusions such as bolt heads, fastener ends, rivets, etc that are excluded from the determination of the FRAME PERIMETER and are within the BUMPER ZONE are permitted.
Again emphasis mine. This declares than anything outside the vertical projection of the frame perimeter is illegal, with the sole exception of things in G30 (not relevant) and fasteners in the BUMPER ZONE. This is good because otherwise all the fasteners you ignored defining your frame perimeter would be illegal. This is bad because any fasteners outside the BUMPER ZONE could be illegal.
Bringing it all together:
1. FRAME PERIMETER is defined by the large black plate in above photo.
2. Axle bolt heads are outside said black plate.
3. Axle bolt heads are outside BUMPER ZONE.
4. QED, axle bolt heads are illegal in above photo.
Yes, it's a bit silly. No, I don't really think it's a useful rule as written. Yes, I'm going to hate having to explain this to 30 odd teams at Lone Star. Nevertheless, the rules as written are entirely clear on it, and I wouldn't want to lay odds on inspectors at my particular regional turning a blind eye to it.
Unread 10-03-2010, 16:04
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Poor little compressor!
Have you had any problems with the chain between the center wheels contacting the bump as you go over?
Unread 10-03-2010, 17:43
hipsterjr's Avatar
hipsterjr hipsterjr is offline
Your bot can score but can it dance
AKA: CJ
FRC #4451 (The Burning Magnetos)
hipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond repute
Send a message via AIM to hipsterjr
You should really look into getting that cylinder its own zip code, just to be on the safe side.
2010 Palmetto Chairmens Winner
2009 Peachtree Finalist Thanks 1319 & 590 "Sure your robot can score, but can it dance?!"
2008 Palmetto Regional Finalist Thanks 343 & 804
2008 Florida Regional Finalist Thanks 179 & 69
2007 Palmetto Regional winners Thanks 1319 & 832
2005 Palmetto Chairmens Winner
Unread 16-03-2010, 22:12
1369Mascot's Avatar
1369Mascot 1369Mascot is offline
AKA: Kevin C.
FRC #1369 (Minotaur)
Team Role: Mascot
1369Mascot is an unknown quantity at this point
Send a message via AIM to 1369Mascot
The best part about this robot: after all was said and done, it could not lift properly, and we were 5 pounds overweight. So, we cut off the top. I will post a picture of our test hanging soon.
HALF WHAT?? HALF MAN!!
HALF WHAT??
HALF BULL!!
ALL WHAT???
ALL MINOTAUR!!
2004 Peachtree Winners - Allianced with 1002 nd 1057
2007 Tempest N' Tampa Finalists - allianced with 1251 nd 1902
2009 Tempest N' Tampa Finalists - allianced with 801 and 1902 (thanks to 79 for taking over after we broke down)
pic: Team 469's Robot for 2006 pic 2 Don Wright Robot Showcase 10 26-02-2006 21:03
pic: Team 469's Robot for 2006 pic 1 Don Wright Robot Showcase 11 24-02-2006 16:35
pic: Team 1595 Final Robot Rookie TEAM L@@K!!!! sgsdragons Robot Showcase 4 01-03-2005 16:21
pic: Team 237 Robot and Team Scott Shaw 237 Robot Showcase 3 23-02-2005 19:54
pic: Team 114 Real Robot Vs. Inventor Robot James114 Robot Showcase 3 18-02-2005 13:02
