Go to Post "Wow, smells like... physics" - Anna B. [more]
Unread 10-03-2010, 12:43
Itamar's Avatar
Itamar Itamar is offline
FRC #1943 (NeatTeam) & FRC #4590 (GreenBlitz)
Itamar is an unknown quantity at this point
Getting the battery voltage
Hi!
I would like to get the voltage of the battery in the code itself.
I belive this is very possible, but I do not know how to do it.
I have the voltage shown properly on the driver station.
If anyone knows how to get the voltage I would appreciate it.
Unread 10-03-2010, 15:52
Ziaholic's Avatar
Ziaholic Ziaholic is offline
Elec/SW Mentor
AKA: Marc
FRC #1164 (Project NEO)
Ziaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the rough
Re: Getting the battery voltage
Since your jumper is setup correctly, you just need to read Analog Input #8
You'll need an OPEN in your BEGIN.VI, then simply do a GET from that analog input.
There are 10 types of people. Those who understand binary, and those that do not.
Team #1164 - Project NEO Robotics
Unread 10-03-2010, 16:49
Itamar's Avatar
I have already tried that, and it gave me a value of 0, than it also gave me 0 on the driver station.
I will try that again.
Meanwhile, any other suggestions?
Unread 10-03-2010, 19:44
The communication task already acquires Analog Input 8 on slot 1. I don't think the system will let you open it again.
You might be able to modify the Start Communication vi to save the battery voltage in a global variable for you. Find the case where it says "Read the battery voltage every 200ms." and try storing the result of the multiplication in the "0" case into a new global that you can read elsewhere in the project.
Unread 11-03-2010, 11:46
EricWilliams EricWilliams is offline
FRC #2039 (Rockford Robotics)
EricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of light
The real question is, why are you reading the battery voltage on the robot side? That sounds interesting.
Unread 11-03-2010, 13:06
Racer26 Racer26 is offline
Alternately, just wire the 12V into another AI port and read that.
Unread 11-03-2010, 13:41
12V is outside of the range of the analog inputs. A voltage divider would be required for this configuration.
If you aren't seeing it on the driver station, you may be missing the jumper that selects it.
Unread 11-03-2010, 14:06
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Here is the odd thing. Like the OP, we do not display the battery voltage on the drivers station. It worked just fine until we applied the last updates to both the cRio and the DS. Now it only gives us "0.00".
The jumper is on the outer two pins of the analog bumper, exactly where it was before the update. Other than that, everything works perfectly.
Any ideas?
Unread 11-03-2010, 16:53
Any ideas?
Is the green power LED lit on the analog breakout board?
Unread 11-03-2010, 16:59
billbo911's Avatar
Yes sir. Our Gyro on Ch.1 works as well, so we know the board is getting power to the bumper.
It really seems odd to us. The ONLY thing we changed between when it worked and when it didn't was the curio firmware and the DS software.
Unread 15-03-2010, 20:02
Zme Zme is offline
FRC #2619
Zme is on a distinguished road
we had an issue similar to this but the problem was intermittent, eventually traced it back to a flakey jumper, try changing it out see if that makes a difference
Unread 15-03-2010, 21:31
billbo911's Avatar
This is what I'm leaning toward as well. It will be one of the first things we check when we open the bag.
Unread 24-03-2010, 14:16
billbo911's Avatar
Well, the jumper checked out normal. So now we are at a loss. We will have the robot out of the bag for four hours this Saturday, hopefully we can figure this out.
Does anyone else have any ideas what may be preventing this from working correctly?
Again, it worked fine until we did the last cRio and DS updates.
Unread 26-03-2010, 00:28
Joe Hershberger Joe Hershberger is offline
National Instruments
AKA: jhersh
FRC #2468 (Appreciate)
Joe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to all
Any chance your code is now opening channel 8 on its own? This will cause a resource in use error. I'm guessing your module is ok since you said the gyro works... metal shavings in the db15 connectors can kill the slot and make all channels return 0.
If you have both analog modules installed, you could read the battery voltage from the slot 2 module.
-Joe
Unread 26-03-2010, 01:18
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
We've seen this before when the analog breakout itself went bad at MARC last year - we were helping the robot next to us and NO one could figure out why they weren't getting battery voltage - so we started swapping out hardware.
You might try swapping your analog breakout.
Battery voltage Yuan Xue Lim Electrical 7 04-02-2009 23:10
paper: Reading the FTC Battery Voltage PhilBot Extra Discussion 4 16-01-2009 08:46
[FTC]: Reading the 12V Battery voltage in LabVIEW PhilBot FIRST Tech Challenge 7 12-01-2009 21:13
The 8.2 (or 8.3) Battery Voltage Bug eugenebrooks Programming 167 21-02-2008 20:05
Battery Voltage Neal Probert Programming 3 09-01-2003 10:18
