Go to Post Waiting for the kick off is like studing the molecular structure of grass while being hit on the head by a frying pan - infinitydex [more]
Unread 10-03-2010, 14:22
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
Placing the socer ball on it's spot
This is a For-What-It's-Worth public service announcement
Some of you may already know this. When placing the soccer ball on the playing field, place it with the air filler nozzle down. This is the heavy side of the ball because of the rubber seal. If you don't, the ball will roll away from you
We now take you back to your regularly scheduled CD posts.
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 10-03-2010, 14:29
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: Placing the socer ball on it's spot
Wow.
I think I placed 20 or more soccer balls on the field last weekend and didn't realize this. I would just keep playing with them until they stopped rolling... I must've looked a bit crazy.
-Dustin Benedict
Unread 10-03-2010, 15:09
coldfusion1279 coldfusion1279 is offline
AKA: Mike
FRC #1279 (Cold Fusion)
coldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud of
Interesting, I didn't notice either. Figured it was just irregularity in stitching.
On a side note, when we place the ball on the spots, how "on the spot" do they need to be?
Does the projection need to cover the spot? Does the bottom of the ball need to contact the spot?
I noticed that some of the spots weren't exactly the same size/shape (small fluctuations). Slight angles in the line of balls over the distance from the far zone makes the difference between the ball bouncing in or out...
Cold Fusion's 10th Season
Unread 10-03-2010, 15:27
thefro526's Avatar
Mentor for Hire.
Mike,
I always placed the center of the ball as close to the center of the dot as I could and then adjusted our robot slightly to get a decent push in...
But, I saw some teams put the balls in placed and it seemed like from the top down the balls would've been covering the dot completely but not necessarily centered on the dot.
You might just want to ask the head ref at your next event.
-Dustin Benedict
Unread 10-03-2010, 16:59
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
As seen here, this "feature" was also present in the poof balls from 2006. My students didn't buy the explanation that dark colors are heavier.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 10-03-2010, 17:01
GaryVoshol's Avatar
Cogito ergo arbitro
Or let it roll to rest, then pick it up and translate it horizontally (don't roll it) to the X. Some balls may have other oddities that make one side heavier than the other.
(since 2004)
Unread 11-03-2010, 20:13
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
This could be tiresome if there's a slight incline.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 11-03-2010, 22:10
qwertyuiop[]\'s Avatar
qwertyuiop[]\ qwertyuiop[]\ is offline
Drive Train/Manipulator Team Leader
AKA: Steven Harris
FRC #0623 (Cougar Robotics)
qwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of light
you guys are way over thinking this. its not hard to put the ball down. the carpet also helps keep it from rolling away.
"...i told you i wanted the left-handed screwdriver not the right-handed one..." always let the mentors get their morning coffee or else they start getting angry and making stuff up.
2005 NASA VCU Website Excellence Award, 2006 NASA VCU Website Excellence Award, 2006 Capital Clash, 2006 Delaware FVC Regional, 2007 Ramp Riot, 2007 Virginia FTC Regional, 2008 NASA VCU Regional, 2008 Battle of Baltimore, 2008 Virgina FTC Regional
Unread 11-03-2010, 22:14
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Not really, balls will roll away. Watching team set up balls, they will roll away about 75% of the time.
Really cool, especially the poof ball phenomenon, never noticed that.
1058 PVC Pirates 2016 - xxxx
Unread 12-03-2010, 07:07
AKA: Warthog
Yes, but than you waste time waiting for the ball to stop. Just put the nozzle side down and it should stay, in place, 99% of the time.
Unread 12-03-2010, 08:15
thefro526's Avatar
Mentor for Hire.
Not really... When your autonomous is done via dead reckoning and the robot has a tendency to drift to the right about 6" over a 15 foot Distance you want the soccer balls to be exactly where you place them. A 1/2" could, and has been the difference between us scoring and simply pushing balls into the wall in Autonomous.
-Dustin Benedict
Team 558 placing the ball and scoring Norm Plude Robot Showcase 12 20-02-2008 06:42
Ball hard spot Nine9cracker Kit & Additional Hardware 13 14-01-2006 12:06
pic: It's a bird.. It's a plane.. It's the 573 Mech Warrior bot! Lisa Perez Robot Showcase 3 27-02-2005 15:09
pic: 16 placing the 2x ball on the stationary goal CD47-Bot Extra Discussion 4 30-03-2004 12:37
#9 seed seems to be the spot to be.... archiver 2001 1 24-06-2002 03:00
