Go to Post Who would have thought a triangular robot would fit into a triangular goal :rolleyes: - Wayne Doenges [more]
Unread 10-03-2010, 17:19
The Engineer The Engineer is offline
FRC #2607
The Engineer is an unknown quantity at this point
Re: Multiple Autons
Ok i really have very little preference to how the switch is made i am just looking for help with the code. if you can tell me anyway to set and switch between autons that would be fantastic
Unread 10-03-2010, 18:13
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Re: Multiple Autons
Here is a sniippet of our code that handles auton switiching. It is sanitized, and not all variables are shown declared.
Switching takes place during disabledPeriodic. Care should be taken in teleopinit to clean up after autonomous before heading into teleop mode so that nothing unexpected happens.
public void autonomousPeriodic()
        this.getWatchdog().feed();
        switch (autoMode)
            case 1:
                // Add kick three balls in goal code here
                message("Performing auto in FAR field");
                break;
            case 2:
                // Add kick two balls in goal code here
                message("Performing auto in MID field");
                break;
            case 3:
                // Add kick one ball in goal here
                message("Performing auto in NEAR field");
                break;
            default:
                // Auto program isn't working so do this instead
                message("Doing nothing");
                break;
    public void disabledInit()
    public void disabledPeriodic()
        // Using joystick trigger to switch modes
        if (!autoTrigger && js_right.getRawButton(1))
            if (autoMode < 4)
                autoMode++;
            } else
                autoMode = 1;
            autoTrigger = true;
        } else if (!js_right.getRawButton(1))
            autoTrigger = false;
        // Update message at driverstation to reflect current
        // mode selection
        switch (autoMode)
            case 1:
                message("1. Autonomous for FAR field");
                break;
            case 2:
                message("2. Autonomous for  MID field");
                break;
            case 3:
                message("3. Autonomous for NEAR field");
                break;
            default:
                message("Do Nothing...in any position!");
                break;
public void message(String s)
        String temp = s;
        if (!temp.equals(userMessage))
            //System.out.println(s);
            userMessage = temp;
            int length = s.length();
            //int numRows = 1;
            String[] row = new String[6];
            for (int i = 0; i < 6; i++)
                row[i] = "";
            if (length > 20)
                int backwards = 5;
                int index = 0;
                // Each line can only hold 21 characters, so
                // break the line in reverse at a space.
                // This will end up not working if a message is STILL
                // too long.  Program must ensure not to send messages
                // too long.
                while (length > 20 && backwards >= 0)
                    index = temp.lastIndexOf(' ', 20);
                    row[backwards] = temp.substring(index);
                    row[backwards].trim();
                    temp = temp.substring(0, index).trim();
                    length = temp.length();
                    backwards--;
                row[backwards]=temp;
            } else
                row[5] = temp;
            // Erase the message box
            DriverStationLCD.getInstance().println(DriverStationLCD.Line.kMain6, 1, "                      ");
            DriverStationLCD.getInstance().println(DriverStationLCD.Line.kUser2, 1, "                      ");
            DriverStationLCD.getInstance().println(DriverStationLCD.Line.kUser3, 1, "                      ");
            DriverStationLCD.getInstance().println(DriverStationLCD.Line.kUser4, 1, "                      ");
            DriverStationLCD.getInstance().println(DriverStationLCD.Line.kUser5, 1, "                      ");
            DriverStationLCD.getInstance().println(DriverStationLCD.Line.kUser6, 1, "                      ");
            DriverStationLCD.getInstance().updateLCD();
            // Now write the data
            DriverStationLCD.getInstance().println(DriverStationLCD.Line.kMain6, 1, row[0]);
            DriverStationLCD.getInstance().println(DriverStationLCD.Line.kUser2, 1, row[1]);
            DriverStationLCD.getInstance().println(DriverStationLCD.Line.kUser3, 1, row[2]);
            DriverStationLCD.getInstance().println(DriverStationLCD.Line.kUser4, 1, row[3]);
            DriverStationLCD.getInstance().println(DriverStationLCD.Line.kUser5, 1, row[4]);
            DriverStationLCD.getInstance().println(DriverStationLCD.Line.kUser6, 1, row[5]);
I don't need a signature.
Unread 11-03-2010, 14:30
ideasrule's Avatar
ideasrule ideasrule is offline
FRC #0610 (Coyotes)
ideasrule is a jewel in the roughideasrule is a jewel in the roughideasrule is a jewel in the roughideasrule is a jewel in the rough
Re: Multiple Autons
Since it doesn't seem like you're the programmer who coded autonomous, get that programmer to do it. It's not a good idea to mess around with somebody else's code because it's very easy to break something or make an error that's super hard to fix.
[FTC]: Multiple Programs or One Program with Multiple Auto Modes kevin51292 FIRST Tech Challenge 4 02-01-2009 20:37
Hosting multiple sites in multiple VMs EHaskins Website Design/Showcase 6 22-12-2007 01:09
Multiple Auton's Joe Clohessy Programming 17 11-02-2005 18:46
Multiple RCX's Noah Melamed FIRST Lego League 1 25-01-2005 15:55
