Go to Post I'm so conflicted right now. On one hand, you made the same page as a celebrity. On the other hand.... Justin Bieber. - Akash Rastogi [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 09-03-2010, 15:59
Geek 2.0 Geek 2.0 is offline
FRC #0107
Geek 2.0 will become famous soon enough
CAN Cables
Hey, just wanted to know where you all get your cables. Anyone make their own? It seems to make sense, because you never need as much as they give you or you never get enough.
If you do make your own, where do you get supplies?
If not, where do you buy your cables?
Unread 09-03-2010, 16:29
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Re: CAN Cables
The CAN cables aren't the same as the kind of phone wire you'd find at radio shack, so we make our own. It's easy if you have the tools
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 09-03-2010, 16:41
skimoose's Avatar
skimoose skimoose is offline
Parent/Mentor/Engineer
AKA: Arthur Dutra
FRC #0228 (GUS)
Team Role: Electrical
skimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond repute
Re: CAN Cables
I think you meant the cable is the same as Radio Shack, just the pin outs may be different. Shop around their are other places to buy supplies for less cost.
We've made all of our CAN bus cables. Get an good phone terminating tool. Four and six conductor flat phone cable and RJ11 4 conductor and 6 conductor terminals. Just pay attention to wire orientation.
2009 CT Regional Motorola Quality Award
2010 VRC Connecticut Championship Winners & Amaze Award
2010 VRC Championship Divisional Energy Award
2010 WPI Regional Winner
2010 WPI Regional Engineering Inspiration Award
2011 WPI Regional Chairman's Award
2012 WPI Regional Finalists
Unread 09-03-2010, 21:41
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Re: CAN Cables
We used CAT5e cable, with stranded wire. We had noise issues with normal phone cable.
Unread 09-03-2010, 22:10
The Lucas's Avatar
CaMOElot, it is a silly place
Re: CAN Cables
Instructions and Digi-Key part #s can be found in the last chapter of this PDF
More info and the BDC-COMM app (connect laptop to CAN) can be found on the Luminary Micro site
Robot Inspector
Unread 09-03-2010, 22:26
FRC #0107
Re: CAN Cables
Did you just leave 2 of the wires unconnected? Sounds like an awesome idea!
Unread 10-03-2010, 09:10
Kingofl337's Avatar
AKA: Adam
Re: CAN Cables
Yes, we left the Brown Pair unused.
Unread 10-03-2010, 11:29
FRC #0107
Re: CAN Cables
Where did you get your endings/cable/crimper?
I don't know if Radio Shack has the stuff, but I'm pretty sure some home improvement stores have them. Anyone know?
Unread 10-03-2010, 12:11
The Lucas's Avatar
Re: CAN Cables
Everything except the supplies for the RS232 cable (haven't found any stores that stock 6 pin RJ12 connectors), can be found at Radio Shack at typical convenience prices (about twice the price for RJ11 ends as Digi-Key). The Getting Started Guide at Luminary Micro's site (which can't be direct linked like in my last post) has the part numbers for Digi-key and instructions for the cables. If you dont want to spend the money on the modular adapter and 6pin cable for the RS232 Cable then you can order some RJ12 some sort of DB9 connector (you might have some of these from previous years).
Robot Inspector
Unread 10-03-2010, 13:06
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: CAN Cables
We made our own. As others have indicated, getting the RJ-11 and RJ-12 isn't too bad - they're available at most places online (digikey, allied, mouser, newark, etc), and at Radioshack (our local store had both available). Add in a cheap $20 crimper, and you're set.
As for the wires... we got ours from our primary sponsor, Boston Scientific. As it turns out, one of the testing labs here was doing something with some wire terminals from another company. To get the terminals, they had to buy the whole cable (about 4 feet long per unit), but all they needed was the terminals on it. So they cut off the terminals, and were going to trash the rest of the cable. We snatched it up It's got 4 wires running through a nice, flexible outer sleeve. The only downside was the color coding - two white and two black. That just means we had to use a multimeter to ensure we got them in the right order
Unread 10-03-2010, 17:23
movax movax is offline
movax is an unknown quantity at this point
Re: CAN Cables
CAN is ridiculously tolerant of errors (I don't know what baud rate the FRC Jags operate at). You can just take two 28AWG wires or so, vise-clamp one end, put the other ends in a drill, and make some twisted-pair to carry the signal. (And then sleeve/braid it if you want).
Unread 11-03-2010, 00:37
duane's Avatar
duane duane is offline
FRC #0701 (RoboVikes)
duane is an unknown quantity at this point
Send a message via AIM to duane
Re: CAN Cables
We found most of our supplies at our local ACE hardware store, including wire, connectors, and crimpers. Be aware that the crimpers you need will be six conductor crimpers. One of the connectors (the one with the serial cable) must be 6 wire. The rest can be four wire. This mistake wasted several days while we had bad connections on our serial cable.
Duane Murphy
Mentor - Software
Vanden Vikings FIRST Team 701
http://www.vandenrobotics.com
Unread 16-03-2010, 20:12
taichichuan's Avatar
taichichuan taichichuan is offline
Software Mentor
AKA: Mike Anderson
FRC #0116 (Epsilon Delta)
taichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud of
Send a message via AIM to taichichuan
Re: CAN Cables
You can find everything (connectors, crimper, wire) at your local Lowes or Home Depot. They're pretty standard for home phone installations. Just make sure that you get the 6P6C RJ-12 connectors and associated crimper. Also, don't forget to flip the connector on one end to get pin 1 to pin 1 etc. connectivity.
Good luck,
Mike
Unread 20-01-2011, 14:42
rudiet rudiet is offline
FRC #1706 (Rachet Rockers)
rudiet is an unknown quantity at this point
Re: CAN Cables
ok, i having some difficulty on how the wires are to be built, are the wires in the CAN cable reversed (AKA 1>6, 2>5, 3>4, 4>3, 5>2, 6>1)
and if that is so, would this work for the connection to the cRIO?
DB9 RJ12 Jaguar
3 -TXD 6 1 - RXD
5 2
100 Ohm 4 3 - CAN H
100 Ohm 3 4 - CAN L
5 - GND 2 5 - GND
2 - RXD 1 6 - TXD
I would like not to have to build a specail cable for just going from the adapter on the cRIO to the first Jaguar. I would perfer to have all the specal changes in the the DB9 to RJ12 adapter.
Thanks!
Unread 20-01-2011, 14:59
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
Re: CAN Cables
the wires are NOT reversed. it is a through cable.
if you are using the db9 adapter with the rj12 jack, be aware that many have reversed pinouts. i killed one finding that out... sure, they were $.50 a pop, but it still was annoying.
if you have any questions, be sure to read this:
http://www.chiefdelphi.com/media/papers/2433
it's a document I recently wrote with everything you would ever want to know about making the wiring work for CAN.
Cables MHSrobotics2853 Technical Discussion 4 19-01-2010 12:14
PWM cables... Where can i buy them??? M. Gildner Electrical 10 11-02-2009 12:31
Y-cables fishgurl Electrical 4 01-02-2008 23:48
Can we shorten the PWM cables? RAWdealer59 Electrical 3 18-02-2003 15:49
No cables? archiver 2000 5 23-06-2002 22:43
