Go to Post The easiest and most effective way to do this for the Championship event is pre-competition scouting, with statistics. Nothing beats it. Hands down. Period. The End. Nothing's better. - Tom Bottiglieri [more]
Unread 08-03-2010, 23:37
Danny Diaz's Avatar
Danny Diaz Danny Diaz is offline
Smooth Operator
AKA: FrankenMentor
None #0418
Danny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond repute
Send a message via AIM to Danny Diaz
Re: Wire color...
As much as we try to help, teams often disregard our advice. A testament to this is teams who mount the breaker panel upside down and have breakers fall out...
Ouch. I happen to fall into this boat; we considered everything that could fall/hang/dangle off/down/from the robot's electrical system (which was mounted upside down as a safety measure against balls and to save space on the robot) - however, I guess we never considered the breakers falling out since we have a hard time pulling them out by hand as it is. But, I guess I can see how this is just another thing we need to consider. Any suggestions on how to guarantee the breakers don't fall out, other than mounting the board right-side up? Has that been a problem with the new Power Distribution Boards?
-Danny
Danny Diaz
Former Lead Technical Mentor, FRC 418
Unread 09-03-2010, 00:06
Re: Wire color...
Danny,
I was speaking to the old fuse blocks. The new PD holds pretty tight until it has been used repeatedly. However, if your robot comes off the bump hard, it might pay to think of a way to put a piece of lexan over the breakers that will not obstruct their view for inspection.
Unread 09-03-2010, 23:14
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
FRC #1322 (G.R.A.Y.T. Leviathons)
joeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant future
Re: Wire color...
-Danny
In 2005 we mounted all of our electric upsidedown and we had no problem with fuses falling out. We also used ruber bands to help hold in the PWM cables. This year every thing is mounted upsideright and our fuses have almost fallen out many times. We have to keep checking them and pushing them back in.
If your not dirty than you must be just watching.
Thank's to http://weberelectric.biz/
FRC Team sitehttp://team1322.org/
2004 Great Lakes Xerox Creativity Award, 2008 Web Site Excellence Award, 2010 Kettering District and Western Michigan District Excellence in Engineering award, 2011 Kettering District Gracious Professionalism Award. 2011 Ann Arbor and State Cooperation Awards.2013 Kettering Xeroc Creativity Award.2015 Escanaba Chairman's Award.2015 Kettering Spirit Award.2016 Kettering Chairman's Award
FTC Lightining Boltz 5954, Thunder Botz 7032http://team1322.org/vex.htm
Unread 10-03-2010, 08:35
Re: Wire color...
Joe,
Are you using a new PD or last year's?
Unread 10-03-2010, 08:39
joeweber's Avatar
Coach team 1322
Re: Wire color...
Joe,
We are using the new one.
I have never seen a game shake up a robot as much as this one.
Unread 10-03-2010, 08:43
Re: Wire color...
That is very odd. Ours is so tight we have a hard time pushing the breakers in. There isn't a chance that the cover has shifted a little and you are inserting the breakers between the cover and the outside of the female terminal is there?
And I know this sounds strange but I have to ask. Have you asked if anyone has made any adjustments to the PD? I have had more than one team stretch open contacts because they thought they were too tight. One was on cable terminals for the Spikes, one was on the old fuse block and one was the main battery connector. The last one produced the most damage.
Unread 10-03-2010, 16:44
joeweber's Avatar
Coach team 1322
Re: Wire color...
How I found the loose breakers was in between matches I noticed a light coming form the fuse panel. I chased it down and one fuse was almost completly out and two others were on there way out. The fuses were the 20 amp type. The larger 40 amp fuses were tight and almost impossible to pull out. Maybe it was not pushed in correct but I don't think so.
Unread 10-03-2010, 19:49
Rapt0r9's Avatar
Rapt0r9 Rapt0r9 is offline
AKA: Tyler
FRC #0747 (Flight Crew)
Rapt0r9 will become famous soon enoughRapt0r9 will become famous soon enough
Re: Wire color...
We were going to mount all of our electronics upside down, but our electrical captain didn't want to have to lay on his back to work on the wiring, so he just hung panels off of the frame. The biggest problem I would see with a board being upside down isn't the breakers, but the pwm cables coming loose. In the past and even this year, we've had a bunch of issues with loose pwm cables causing control devices to cut out during matches.
This year, the pwm cable for our compressor's spike wouldn't seat into the connector if the spike had its housing on. When I just used the internals from the spike, it responded, but as soon as I put the housing back on the spike, there was no communications between the digital sidecar and the spike. After trying different spikes and different cables, I cut some of the housing for the spike off allowing the cable to sit lower and that was the last we saw of that problem.
BS Information Technology - NJIT (2009 - )
Team 869 (2004 - 2008, 2011 -), Team 1811 (2010), Team 869 (2009), Team 613 (2009 - 2010)
"Nothing in this life worth having comes easy."
Unread 10-03-2010, 23:56
Danny Diaz's Avatar
Smooth Operator
AKA: FrankenMentor
None #0418
Re: Wire color...
I've been playing with another PD that we have in our shop right now - I have also noticed that the 40-Amp fuses on the new PD are next to impossible to put in and take out, but some 20-amp fuses are easier to pull out and some are waaaay too easy to pull out (I don't remember them being that loose on our robot, and I know none fell out during our pre-ship scrimmage). I'm definitely taking your advice and mounting a plexiglass panel over the PD once we get to Dallas next week, better safe than sorry.
Thanks!
-Danny
Danny Diaz
Unread 11-03-2010, 00:04
Danny Diaz's Avatar
Smooth Operator
AKA: FrankenMentor
None #0418
Re: Wire color...
We used zip-tie mounting plates (1"x1" plastic self-adhesive pads) and forced the PWMs into tension against our Spike and Victors by zip-tying the PWM cables to the mounting plates. The Jags have the tension "clips" that we used to prevent the PWM's from falling out. With this, we cannot even pull the PWMs out by hand without cutting the zip-ties.
You aren't using a male/female adapter on the PWM cable, are you? We find that those male-male (pretty much a 3-pin header almost) adapters do not fit into Victors or Spikes nicely, you've got to use the Universal Servo connector with the pins built into the plug. Otherwise, you have the issue you mention, and it doesn't stay plugged in very long no matter what you do.
-Danny
Danny Diaz
Signal wire gauge and color. sparrowkc Electrical 4 10-03-2010 19:51
Does the Trackball Color Match your team Color??? ZInventor Kit & Additional Hardware 14 07-03-2008 20:09
Color? neilcooper Technical Discussion 2 11-01-2005 16:58
Team Color DrWorm Control System 1 02-02-2004 19:02
Link color Jack Website Design/Showcase 4 19-11-2002 16:31
