Go to Post Good engineering often comes down to knowing the difference between "better" and "good enough." - dlavery [more]
Unread 10-03-2010, 20:17
Re: Raw Voltage on Cypress
Originally Posted by manderson5192 View Post
If I remember correctly, they want to put a 7-segment LED display (or a row of LEDs) on to indicate the kicker "power level" they're requesting of the kicker (insert >9000 reference here...), individual LEDs to give camera feedback to the driver (one LED means they're aimed too far left, one means too far right, and a center one means they're ready to kick), a single LED to indicate that the kicker leg is wound and ready to release.
Why not just use the Dashboard for all this? Our custom dashboard has a kick power meter (ours goes to 11), an "armed" indication, camera feedback with directional indicators, drivetrain status, etc.
The idea of using "super bright" LEDs is that the driver doesn't need to wear an annoying, clunky HUD. Rather, it will be very obvious from peripheral vision and ambient light to know what the robot's state is (different color LEDs at different positions indicate different things).
That scheme sounds like it would be very easy to put on the Dashboard.
Cypress board bls0620 Electrical 4 17-01-2010 23:22
Cypress soc? sp33chy FRC Control System 2 15-01-2010 08:58
Raw Camera Data WatersongX C/C++ 8 03-02-2009 09:20
Served Raw Chicken at Burger King. MattK Chit-Chat 19 10-11-2005 00:56
Voltage Byte -> True Voltage Ulibrium Technical Discussion 11 01-03-2002 08:55
