Go to Post Thanks to team 1114 and 1503 for not wiping the floor with us. - SpaceBoy2000 [more]
Unread 11-03-2010, 14:11
Re: FP ok to stall?
As a general rule of thumb, unless the datasheet or other documentation says otherwise, most DC motors are designed for continuous operation at about 20% of rated stall torque (aka 20% rated stall current). Operation at higher torques (currents) is allowed, but only intermittently. Ambient temperature, heat sinking, and forced airflow affects the allowable length of the intermittent period.
Toughbox stall torque Galum Motors 4 04-02-2010 15:47
motor stall current vs Victor ratings dawilliams Electrical 30 03-01-2007 08:29
Made to stall srjjs Motors 5 17-01-2003 19:00
What happens / why do motors stall? DanL Technical Discussion 19 21-11-2002 07:19
So you want to stall a Globe Motor... archiver 2000 1 24-06-2002 00:09
