My love spiders out in a web of emotions when I think of you.
Unread 11-03-2010, 19:24
slicer800 slicer800 is offline
FRC #0569
slicer800 is an unknown quantity at this point
Deployment issues
Hi guys, when i try to build the program into my crio i click run as start up first and when it finishes it says completed with errors so i looked to see what was the problem it says that the FRC Deployment (failed to deploy) what could be causing this? and how can i fix? Also If we don't have the gaming adapter (black box) and we plug the labtop into the crio and then unplug the lab top connector and replug it into the blue box into ethernet 1 would this work to run the robot? ( I'm asking this because we left the gaming adapter on the robot when we shipped it out and we forgot to take it off.)
Thanks,
~ Team 569
Unread 11-03-2010, 19:58
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: Deployment issues
A few points here - Open Robot Main.vi and look for a play button near the upper-left corner. If it is broken, you have a code error that would explain everything.
The gaming adapter makes no difference in code downloading. It's kinda hard to understand what you mean with your networking connections, but you should be able to connect the laptop directly to the cRio with a crossover cable and download. If you want to run the robot, you could go through the router. It makes no difference. The job of the networking, router, and gaming adapter is to route the data from the laptop to the cRio, so as long as the laptop can connect to the cRio it will work. If you have problems, then remove the wireless link and use a crossover cable.
Kettering Motorsports
Unread 12-03-2010, 01:04
Ziaholic's Avatar
Ziaholic Ziaholic is offline
Elec/SW Mentor
AKA: Marc
FRC #1164 (Project NEO)
Ziaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the rough
I was just about to post a BREAKTHROUGH thread about a magic trick I learned today because I was getting your exact same problem today at the Arizona Regionals.
... send $100 to my paypal account and I'll PM you ...
OK, here's the magic trick that NI's rep gave me today ... [I'll edit this post with with Kudos (and his correctly spelled name) after I see him tomorrow]
1) on the cRIO, set the No App dipswitch to TRUE (this prevents user code from running when the cRIO boots, regardless of the SW settings)
2) reset the cRIO and feel free to deploy/run/build/set-as-startup, whatever ... As long as that dip-switch is set, it'll never run the startup apps when it boots, and the deployents (or just hitting RUN in the RobotMain.VI) works every time.
3) when you are done debugging and/or troubleshooting and want to try it out in a "realistic" fashion, do a final build and Set as Startup.
4) when the upload to the cRIO is complete, there's a window to close and then it asks you to reboot the cRIO. Before you click the Reboot button, UNSET that dip-switch
He said that they are looking into why this is occurring, but apparently they've got a pretty good workaround until we get a patch.
After I learned this trick, I never saw those errors again, and we were slinging code onto our 'bot all day today (Practice day at the AZ regionals)
Hope this helps.
There are 10 types of people. Those who understand binary, and those that do not.
Team #1164 - Project NEO Robotics
Deployment Communications Fail alex42 FRC Control System 7 22-02-2010 07:31
Deployment Time SpaceOsc NI LabVIEW 1 06-02-2009 13:18
Wireless Deployment / Ipconfig p00rleno NI LabVIEW 3 31-01-2009 12:28
Ramp deployment a hazard? marc Rules/Strategy 7 11-02-2007 10:54
