Go to Post When's the last time you called up FIRST headquarters just to say thanks? Or saw a volunteer at a regional and said, 'Hey, you're doing a really great job here. Thank you for everything you're doing in your spare time.' - Amanda Morrison [more]
Unread 11-03-2010, 20:38
zip100 zip100 is offline
FRC #0640
zip100 is an unknown quantity at this point
pneumatic kicker
I wanted to know if this code will allow the kicker to extend and automatically retract or do I need to assign a button for it to retract. I doubt that we are using a double solenoid.
Unread 11-03-2010, 20:49
DonRotolo's Avatar
Back to humble
FRC #0832
Re: pneumatic kicker
The code can be written to do anything you can imagine, including that. Ours does.
I'm not a programmer, so I can't help there, but I guarantee it can be done.
Unread 11-03-2010, 20:50
FRC #0640
So if i press button 1 it will shoot out and then immediately go back into its start mode by itself?
Unread 12-03-2010, 10:51
That code will activate the solenoid exactly while the joystick button is pressed. If it's a single solenoid valve with the pneumatic tubing connected normally, the cylinder it is controlling will move to one end of its travel when the button is pressed (and the robot is enabled, and in teleop, and the "seek target" button is not also pressed), and it will return to the other end when the button is released.
Programming Autonomous pneumatic kicker tanguma26 NI LabVIEW 14 07-03-2010 21:40
Need Help - Pneumatic Kicker cardozo NI LabVIEW 3 03-03-2010 16:40
Team 1522's pneumatic kicker kornjones Robot Showcase 0 15-02-2010 20:59
pic: Pneumatic Kicker Rev_1 professor1212 Extra Discussion 6 17-01-2010 23:07
pic: Pneumatic Kicker Rev_0 professor1212 Extra Discussion 0 17-01-2010 01:15
