Go to Post "It doesn't matter what you think happened, what the Ref calls (or doesn't) is what happened. The judgement of the Ref is part of the game, live with it or don't play." - ChrisH [more]
Unread 09-03-2010, 15:42
rwood359 rwood359 is offline
AKA: Randy
FRC #0359 (Hawaiian Kids)
rwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to all
Networking remote dashboard
We have a USB to Enet converter that we connected to the Classmate USB and the Remote Dashboard laptop Enet connector. We set the USB adapter in the Classmate 10.3.59.X and the laptop to 10.3.59.Y (unused IPs). Using the network connections control panel, we bridged the standard and new connections on the Classmate. Everything worked fine when we selected Remote Dashboard on the drivers station. At the San Diego Regional, we had a problem communicating with the FMS. We had a red LED for Enet on the DS Diagnostic tab that appears to be caused by the bridged connection. The field tech said that the bridged connection is not a supported configuration. That killed our remote dashboard.
Is there a way to configure the Classmate to allow communication using the USB/Enet adapter? If so, can anyone give us a hint on how it is done?
Unread 09-03-2010, 20:53
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Re: Networking remote dashboard
You must use a subnet other than 10.0.0.0/8, your team IPs are in this subnet.
For example if you use 172.3.69.0/24, it would work without any issues. However, without additional software it is not possible to have a camera feed on the second computer.
Exampel setting to use:
DS:
USB IP: 172.3.69.1
USB Subnet mask: 255.255.255.0
USB Other settings: empty
Forward dashboard to: 172.3.69.2
Remote DashboardPC
IP: 172.3.69.2
Eric Haskins KC9JVH
Unread 09-03-2010, 23:40
AKA: Randy
Thanks for the information. I'll try it Thursday in Phoenix. But without the camera, the Dashboard isn't very useful.
Unread 10-03-2010, 11:41
slavik262's Avatar
slavik262 slavik262 is offline
We do what we must because we can.
AKA: Matt Kline
FRC #0537 (Charger Robotics)
slavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to behold
Send a message via AIM to slavik262
What do you mean by additional software? Do you mean software that forwards packets throught the Classmate? What do you suggest using for this?
Unread 10-03-2010, 12:16
buchanan buchanan is offline
FRC #2077 (Laser Robotics)
buchanan is just really nicebuchanan is just really nicebuchanan is just really nicebuchanan is just really nice
Is there documentation available as to how "dashboard forwarding" is intended to work and what's legal vs what's "not supported?" There are clear rules about physical and wireless network connections, and reasonably clear statements about port blocking, but where were we supposed to learn that the OP's configuration (which sounds a lot like what we've been doing) was somehow forbidden? If the remote dashboard/video tools use the same cRIO ports, protocols, and subnet as the provided classmate dashboard/video software, and run over legal physical connections, what's been violated? This does not sound to me like a matter of something not being "supported," it sounds more like something's been done to explicitly prevent it. Is that "something" documented anywhere?
Surprise or no, if the classmate-remote subnet must be different than the 10 subnet, why is it that the remote dashboard (proper) would expect to work over it while a remote video monitor wouldn't? Does the "forwarding" mechanism support one but not the other?
Unread 10-03-2010, 23:29
AKA: Randy
When we had the two connections "bridged", the indicator by Enet Link on the Diagnostic tab of the Driver's Station was red. That was what caused the tech to say that the mode was not supported. We had other problems at the time so I don't know if the FMS link would have worked with the bridged connections. If we have a practice match to waste (small chance) tomorrow, I'll try bridging again.
Unread 11-03-2010, 02:59
We'll be trying out our setup at the WI regional starting tomorrow morning - we'll find out.
Having spent some more time digging, I suspect they may be blocking all hosts on the 10.0.0.0 network except 10.x.y.z where x.y is a registered team number and z is either the cRIO (2) or Classmate (5?). I guess it makes sense, but it would have been nice to have been told this earlier (or were we?)
Another interesting data point is that we ran a couple of weeks ago at the Sussex WI practice meet under a presumably semi-official FMS without any problem.
We're working on a proxy dashboard to forward both the dashboard and video feeds in case we find out tomorrow that our current setup is blocked. I see that EHaskins has also posted what looks to be a similar solution at http://www.chiefdelphi.com/forums/sh...ad.php?t=84147
The other piece is to reconfigure the USB adapter to make a separate network rather than bridging on to 10.0.0.0. I'm trusting that's easy but haven't looked...
Unread 11-03-2010, 21:38
Kitmor's Avatar
Kitmor Kitmor is offline
AKA: Kit Morton
FRC #0847 (PHRED)
Kitmor will become famous soon enoughKitmor will become famous soon enough
Our team had the same issue at the Oregon regional.
We had a usb NIC and had the network adapters bridged, and when it was like that, we could never get communications to our robot on the field. I don't know what it was that was causing the conflict, but as soon as we removed the bridge, the communications issues went away. I am wondering if FIRST was intending for us to have a separate dashboard this year on the field, because I'm not certain how else it is possible to attach the dashboard.
-Kit
"Stand back we don't know what it is going to do"
Unread 11-03-2010, 23:40
phobozad phobozad is offline
AKA: Burger
FRC #0537
phobozad is an unknown quantity at this point
I can confirm that you cannot connect to the FMS with a bridged connection and another computer hanging off of it. As soon as the FMS system detects more than one computer attached to the field, they cut you off from field management. That being said, someone might try disabling ICMP on the attached laptop and/or firewalling off everything except the needed ports for dashboard data and video.
If that doesn't work, you will need to either write or find some software to read packets off the field interface and resend them on the USB ethernet interface. The only other option is turning the Classmate into a router, which is trivial and requires no extra software. Unfortunately, to make this work you need to add a default gateway or static route to the cRIO, which I haven't found a way to do yet (let me know if you know how).
However, if you only need dashboard data and aren't trying to get video on the second laptop, EHaskins' instructions are all you need - you can enter what IP you want to forward to with the "remote dashboard" function in the DS software.
That presumption would be false. I was one of the ones helping to run that event; specifically I was working the field/control system. We were running the FMS light program, which while it may be semi-official, only provides very basic field control. We're still working on reintegrating and doing a complete overhaul of our FMS, but even then there aren't any plans to restrict access like at official events.
Unread 12-03-2010, 03:18
We successfully ran our last practice match with a separate network, non-bridged, connecting the USB/ethernet adapter to the remote display machine, with a forwarding proxy installed in place of the classmate's local dashboard. So we have at least one configuration proven to work. I expect that's what we'll stick with now.
It's a bit unfortunate that what seems to be a reasonable and useful configuration, apparently not prohibited by the letter or spirit of the rules, is effectively prohibited by a practical limitation of the FMS that wasn't revealed until the last minute.
I'm also a little baffled about how the remote dashboard feature on the DS was INTENDED to work. Was it truly understood by anyone that this was a development-only feature that couldn't be supported in competition?
Unread 12-03-2010, 06:55
slavik262's Avatar
AKA: Matt Kline
The entire thing seems like a bit of a Catch-22 to me. We'll also be switching over to some sort of proxy system today. It's quite unfortunate that this "feature" of the FMS was never revealed to teams. Echoing buchanan, I don't understand what was intended at all, or if there was some lack of communication higher up in FIRST. Despite over and over giving teams the resources and suggesting procedures for running dashboard software on another laptop, it is now impossible to have a second laptop on the same subnet.
Unread 25-09-2010, 11:06
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Our Classmate's ethernet port is hosed and we want to use a usb nic. The device we bought works great on the team laptop, but not the Classmate. Are there any Classmate-particular issues I need to be aware of?
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 25-09-2010, 20:57
The important information to know is whether Windows is recognizing the USB nic or not. Our USB nic works fine, but we had to install the included drivers.
Unread 25-09-2010, 23:06
Jon236's Avatar
AKA: Jon Mittelman
Correct....in addition, it is necessary to disable all other network connections on the Classmate.
Jon Mittelman
remote dashboard mikedeggy General Forum 1 06-03-2010 00:35
camera connected to crio- transmits to remote dashboard not local mcbean Programming 3 28-01-2010 19:10
Remote Remote Kickoff for Southern California ChrisH Southern California Regional Robotics Forum 0 05-01-2004 12:36
Remote Remote Kick off at University High School George1902 Off-Season Events 4 04-01-2004 21:05
Networking Dial-up Ashley Weed Math and Science 13 05-09-2003 23:30
