Go to Post FIRST does not follow patterns. - Mike Soukup [more]
Unread 09-03-2010, 13:06
z.s.tar.gz z.s.tar.gz is offline
FRC #3242
z.s.tar.gz is an unknown quantity at this point
Camera live feed not working
All I want is for the camera to broadcast a live feed back to the driver station. The instructions aren't very clear about this. There is some kind of PCVideoServer class, but I don't really know what to do with it.
Please help, as you can tell I'm a little short on time =P
Unread 09-03-2010, 14:16
Dave Scheck's Avatar
Dave Scheck Dave Scheck is offline
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
Re: Camera live feed not working
All you should have to do is create a new AxisCamera object. It will start the video server for you.
At the top of your file, add
#include "Vision/AxisCamera.h"
Then in your initialization code add this
AxisCamera &axisCam = AxisCamera::GetInstance();
That should get you the video stream back to the default dashboard at the driver station.
Unread 09-03-2010, 14:24
FRC #3242
Thank you. I did that which means that the problem is with my dev laptop downloading the code, or lack thereof.
Unread 09-03-2010, 14:27
Mike Soukup's Avatar
Mike Soukup Mike Soukup is offline
Software guy
FRC #0111 (Wildstang)
Mike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond repute
Also make sure you have the latest DS version installed and (I know this is an obvious one, but I have to mention it) the camera is configured properly according to the instructions that FIRST provided. You should also read over the code in the vision demo project that came with this year's software package. They put some delays before trying to communicate with the camera. Get everything to work correctly with their code, then add the correct pieces to yours.
Unread 09-03-2010, 16:58
FRC #3242
I tried just uploading the code from the camera example onto the robot after I did the DS update again, but it still doesn't work.
Unread 10-03-2010, 10:31
slavik262's Avatar
slavik262 slavik262 is offline
We do what we must because we can.
AKA: Matt Kline
FRC #0537 (Charger Robotics)
slavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to behold
Send a message via AIM to slavik262
The DS update is notorious for not working. The recommended approach seems to be to uninstall the DS software completely, manually delete any files it left behind, and then run the update. That way you make sure there's no chance that the updater is leaving behind things it shouldn't.
To return to an earlier point, the PCVideoServer class is indeed responsible for sending video to your dashboard, but one is automatically started upon getting an instance of AxisCamera.
Unread 10-03-2010, 14:01
Originally Posted by slavik262 View Post
The DS update is notorious for not working...
The first update had an issue that kept it from overwriting the older dashboard app with the newer one, and the effective workaround was to run it once to uninstall everything then run it again to reinstall the proper version of everything. The current update does not have that problem, and the workaround is no longer necessary.
Unread 12-03-2010, 03:02
ideasrule's Avatar
ideasrule ideasrule is offline
FRC #0610 (Coyotes)
ideasrule is a jewel in the roughideasrule is a jewel in the roughideasrule is a jewel in the roughideasrule is a jewel in the rough
Check this:
http://www.chiefdelphi.com/forums/sh...ad.php?t=84179
Unread 16-03-2010, 19:21
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
double-check the physical wiring of the camera
Also, are you letting the system have a bit of time to load? The camera loads later than the cRIO code so there is a delay before images are sent.
What is the color of the ring around the camera lens while the robot is on?
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 16-03-2010, 20:25
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Just want to add that make sure the ethernet cable is a cross-over cable.
Unread 17-03-2010, 22:17
brianelite brianelite is offline
FRC #2898
brianelite has a spectacular aura aboutbrianelite has a spectacular aura aboutbrianelite has a spectacular aura about
   AxisCamera &camera = AxisCamera::GetInstance();
                camera.WriteResolution(AxisCamera::kResolution_320x240);
                camera.WriteCompression(20);
                camera.WriteBrightness(0);
Is our camera code an it works fine... not sure what happens if you only have the first line
2010 FRC Camera Live Feed Lag ideasrule Programming 23 11-02-2010 02:33
Yet Another Axis Camera Live Feed Issue z2daj FRC Control System 2 24-01-2010 13:47
Live Feed with Axis Camera CHSboy Programming 6 24-03-2009 14:43
2009 - Live camera feed to drivers during a match? Travis Hoffman Rules/Strategy 23 21-01-2009 17:43
Getting Live Feed from Axis Camera in Windriver Inoperational C/C++ 8 15-01-2009 01:21
