Go to Post Chairman's Award is not about building the robot. Every team builds a robot. - Retired Starman [more]
Unread 12-03-2010, 16:59
,4lex S.'s Avatar
,4lex S. ,4lex S. is offline
University Mentor
AKA: Alex Strong
FRC #2702 (REBotics)
,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of
Re: putting placards on the robot
R-14 and R-15 are the pertinent rules in this matter. It appears that you require only to have the team number on each side of the robot. Otherwise, you are generally free to do whatever you wish with sponsor and school logos.
If you are looking for a lightweight covering to put logos on, I suggest foamcore. I don't know about other countries, but in Canada you can get black core that is pretty resilient in impact and relatively stiff. 1114's 2008 robot and 1006's 2009 robot both feature this material, which has some form of logo or design stuck onto the foamcore. If you are looking for a cheap source, see if anyone on your team has a friend in the picture framing business. The main benefits of this stuff are that it is cheap, easy to shape, and weighs next to nothing.
University of Waterloo Mechanical Engineering Class of 2014- 2B School Term
University of Waterloo Formula SAE Race Team 2010-Eternity
FRC 2702: REBotics 2011 Mentor ::: FRC 1006: Fast Eddie Robotics 2005-2009 Alumni ::: FLL 4050: 2004 Alumni
Unread 12-03-2010, 17:52
Cynette Cynette is offline
Worry is a poor use of Imagination
AKA: Cynette Cavaliere
FRC #1511 (Rolling Thunder)
Cynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond repute
Send a message via ICQ to Cynette Send a message via AIM to Cynette
Originally Posted by Enigma's puzzle View Post
It is a rule that you need to have the School Name on the robot.
Unless you aren't affiliated with a school.
<R14> ROBOTS shall display their school name (or the name of the supporting youth organization, if appropriate), and primary sponsor name and/or logo whenever the ROBOT is on the FIELD, including practice sessions.
Originally Posted by ,4lex S. View Post
R-14 and R-15 are the pertinent rules in this matter. It appears that you require only to have the team number on each side of the robot. Otherwise, you are generally free to do whatever you wish with sponsor and school logos...
And the team number is on the bumpers and does not need to be on the robot in another location.
<R15> Teams shall display their team number on the BUMPERS in four locations at approximately 90-degree intervals around the perimeter of the ROBOT. The numerals must be at least 4 inches high, at least in ¾-inch stroke width and in a contrasting color from its background. Team Numbers must be clearly visible from a distance of not less than 100 feet, so that judges, referees, and announcers can easily identify competing ROBOTS.
So, any method of getting the school / organization name and main sponsor(s) on the robot is fine. Paint, stickers, paper taped/glued down, or even masking tape with the information written on it will work.
I like the black foam core idea; that would look very classy!
Cynette
The best angle from which to approach any problem is the TRYangle
--Chinese Fortune Cookie
Rolling Thunder, Team 1511: The Thunder just keeps getting louder!
Unread 12-03-2010, 19:28
Rick Wagner's Avatar
Rick Wagner Rick Wagner is offline
FRC #3008 (Kalani Robotics)
Rick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to behold
Please do not use black numbering on the blue bumpers. It's hard to read from a distance. Most visible is white numbers, on both red and blue bumpers.
Unread 12-03-2010, 19:51
Fe_Will's Avatar
Fe_Will Fe_Will is offline
AKA: Will
FRC #0955 (CV Robotics)
Fe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud of
We had black numbers on both colors of our bumpers. We were asked by field management to make it more visible... silver sharpie outline worked great and was a fast and cheap fix.
"It is the mark of an educated mind to be able to entertain a thought without accepting it." -Aristotle
Unread 13-03-2010, 16:23
Meanwhile, I heard at some regionals the inspectors were making teams paint over their contrasting outline to make the numbers a single color.
Unread 13-03-2010, 16:31
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
That is so weird. We have bright blue numbers with white outline. What really makes black numbers a pain is when they are close together and on dark blue bumpers and deep red bumpers!
1058 PVC Pirates 2016 - xxxx
Putting the Compressor into the framework Team2339 NI LabVIEW 2 31-01-2009 19:32
HELP! (Putting music in the animation) auditt241 3D Animation and Competition 26 11-02-2006 13:49
pic: putting the R... shotgunking777 Extra Discussion 1 20-01-2005 14:20
Putting more bump in the CR-V's trunk... Billfred Chit-Chat 5 13-08-2004 15:32
