Go to Post Please drill responsibly! - IKE [more]
Unread 12-03-2010, 22:28
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Programming Pneumatics
The default module for both the switch and relay is slot 4, if this matches your configuration you can leave it unwired, but it doesn't hurt anything to wire in a constant Slot 4 to be sure.
You should wire in a constant for both the switch and relay channel that matches the channel you are using for each on the Digital Sidecar.
EDIT: From the image it looks like you are using controls instead of constants for the module and channel. While this will work if done properly, you probably aren't changing the module and channel very often so a constant is probably more appropriate. Right click on the control and select "Change to Constant"
programming pneumatics holty531 Programming 9 02-02-2008 22:03
PROGRAMMING PNEUMATICS Reaper40 Pneumatics 17 02-02-2008 07:55
Programming Pneumatics? itzrobz Programming 2 20-01-2007 00:30
Programming of Pneumatics Ben Piecuch Programming 3 18-02-2005 02:39
Pneumatics Programming KWalsh Programming 8 19-02-2004 09:17
