Go to Post But before we jump to conclusions, I'll wait for kickoff and the manual. ;) - BrendanB [more]
Go Back   Chief Delphi > Competition > Regional Competitions
Unread 12-03-2010, 22:27
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
team standings as posted by usfirst.org
I only started looking at the team standings as part of the discussion about the effect of TU16 if it were to be applied to week 1 results. There is a column on the team standings page labeled "coopertition bonus." It appears to be a cumulative total of the teams' coopertition bonus points for all their matches. My reading of rule <9.3.8> is that only the highest of each team's CB points is retained as a possible tie-breaker for rule <9.3.9>. So when I see a CB score of 52 in the AZR team standings, for instance, I'm amazed that such a score is possible. Further, since each team on the alliance gets the same CB for a match, I would expect there to be two other 52s in the table. I take the absence of those other two to mean that the numbers in that column are sums.
Can someone take a moment to check my logic about this? It doesn't seem common to be using this tie-breaker, but I wonder if it is being tracked properly.
Unread 12-03-2010, 22:35
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: team standings as posted by usfirst.org
That seems to be correct. Cumulative Coopertition Bonus should be tracked for the Coopertition Award, the single highest should be tracked as a tiebreaker according to my reading of section 9.3.9
Unread 12-03-2010, 22:39
GaryVoshol's Avatar
Cogito ergo arbitro
The figure posted (e.g. 52) seems to be the sum of all coopertition points earned.
(since 2004)
Unread 12-03-2010, 22:43
FRC #2170
Thanks, Kevin, I guess I took the column to be for the tie-breaking use because the next one over is cumulative hanging points; also a tie-breaker possibility. I had forgotten about the CB award aspect.
Unread 12-03-2010, 22:49
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
I agree, it seems like having the highest CB in a column with the cumulative hanging next to it and perhaps the cumulative CB all the way to the right would be more clear as to what is used to rank teams.
With the way it is now it is unclear if the tiebreaker being used is highest single CB or cumulative CB. If they are using highest single CB as seems to be indicated in the manual it seems like it should appear on the standings somewhere.
Unread 12-03-2010, 23:40
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
That would be our team with the 52. The next place team has a 26. Most teams played 7 out of 10 matches already.
At SD last week, there were 2 teams tied for the most CS points. The 1266 team had the tie-breaker in hanging points, hence the award.
Unread 13-03-2010, 08:28
johnr johnr is offline
FRC #0910
johnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond repute
On a different note, i was looking thru the standings for that odd number under hanging points. My thinking being that an odd number would denote a suspended bot. To my surprise there is an odd number at Florida, but it is the number 1. How can you get 1 for hanging?
Unread 14-03-2010, 00:11
Johnny's Avatar
Johnny Johnny is offline
We do it for the pizza
FRC #1266 (The Devil Duckies)
Johnny has a spectacular aura aboutJohnny has a spectacular aura aboutJohnny has a spectacular aura about
Maybe they had a match with one penalty and only scored with one hanging robot? Not completely sure how that would work.
FRC http://www.frc1266.com/
Battlebots http://www.mutantrobots.com/
Unread 14-03-2010, 23:22
leah_2996 leah_2996 is offline
FRC #2996 (Cougars Gone Wired)
Team Role: Scout
leah_2996 is an unknown quantity at this point
I saw the same thing. There were actually two teams at the Florida Regional that got one hanging point- team 1592 and 118. I read that both teams do not have hangers, and I also researched it and found out that they were on the same alliance during match #19 on Friday. Does anyone know how one hanging point is possible?! It's driving me a bit crazy ha ha
Unread 15-03-2010, 10:43
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
Originally Posted by Mark McLeod View Post
You get one "hanging" point for being parked on the tower platform (and touching the tower sides).
Just curious, but where did you get that? this definition:
ELEVATED: A ROBOT that is completely above the plane of the PLATFORM and in contact with the TOWER shall be considered ELEVATED.
And this rule:
<G04> b. Each ELEVATED ROBOT is awarded 2 points, or each SUSPENDED ROBOT is awarded 3 points
Tell me otherwise. The GDC already stated on Q&A that the platform is part of the tower, and that a robot parked on the platform is considered "above the pane of the platform", and touching the tower. I see no rule awarding one point except a scored ball.
The way I read it, if you are parked on the platform, and no part of your robot is below the platform, regardless of whether or not you are touching the support poles for the tower, you get two bonus points.
Former Mentor Team 1771
Former mentor Team 4509
Unread 15-03-2010, 10:55
No, I was wrong. I'd misremembered the point count at the end of the game animation.
The Head Ref at NJ addressing the driver teams did demonstrate that the robot on the platform was not considered elevated unless it also was touching part of the tower structure, e.g., a side pole, but I can't say if that interpretation was correct or even changed subsequent to the first week's regionals.
Unread 15-03-2010, 11:23
martin417's Avatar
AKA: Martin Wilson
According to this Q&A answer, the head ref was, regrettably, incorrect.
Old 01-14-2010, 11:28 PM
GDC GDC is offline
Game Design Committee
Default Re: <G30> Tower Contact - Platform
A ROBOT that is resting on top of the PLATFORM, with all parts of the ROBOT completely above the plane of the PLATFORM, is both in contact with the PLATFORM (which is part of the TOWER) and above the plane of the PLATFORM. Therefore, the definition of "ELEVATED" is satisfied.
Unread 15-03-2010, 12:20
FRC #0910
I will go with what someone said earlier about a penalty knocking it down to one. Since there is no third team with a odd number i would guess that team was either a complete no-show or that team was dq'd.
Unread 15-03-2010, 12:34
Steve W Steve W is offline
Grow Up? Why?
Steve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond repute
Originally Posted by Rizner View Post
I disagree, the platform is part of the tower structure. The head ref seems correct in their statement to me.
I think that you misread the previous post. He was stating that the head ref would be wrong if they ruled that the robot on the platform had to be touching the poles to count. As you have noted and was in the rules, if the robot is on the platform then it is in contact with the tower even if it is not touching a pole.
We do not stop playing because we grow old;
we grow old because we stop playing.
Unread 15-03-2010, 12:37
martin417's Avatar
AKA: Martin Wilson
What statement is that? I wasn't there, but according to Mark McLeod
.....The Head Ref at NJ addressing the driver teams did demonstrate that the robot on the platform was not considered elevated unless it also was touching part of the tower structure, e.g., a side pole, .....
If the head ref actually stated that a robot is not elevated unless it was touching a side pole, then he was incorrect.
USFirst.org Down? Kingofl337 Rules/Strategy 6 24-02-2008 19:17
usFIRST.org Down? Andrew Bates General Forum 14 15-12-2007 00:52
www.usfirst.org Captain Rich General Forum 9 18-05-2005 13:37
USFIRST.org Trouble n_0163 General Forum 7 07-03-2005 09:50
Usfirst.org LizJJury General Forum 1 03-02-2003 17:10
