Go to Post A well-designed shifting transmission, controlled by an experienced driver (or a clever bit of software), is an advantage. - Alan Anderson [more]
Unread 14-03-2010, 01:17
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: Hight score of the season
Originally Posted by Formerly Famous View Post
Maybe it's not traction you need... F=m*a So would a robot that weighs around 110 pounds(maybe 120, which would put it 130 with the battery) so with enough acceleration, (driving right under the tunnel) couldn't they pop it out, and then push them backwards enough to disrupt the strategy? (Not saying I would recommend this, I'm just saying it's possible.)
Just my $.02
Keep in mind that 469 is able to apply a force in opposite direction that this robot is pushing. Your acceleration (and therefor your force in the "pushing axis") is hinged upon the force you apply to the floor (very same F=ma equation you mentioned). That force is limited by the friction that the robot can generate, which is governed by the coefficient of friction of the wheels and the normal force of the robot. Because of 469's mechanism, their normal force is going to be much larger than the pushing robot, and thus they're going to have a much higher "pushing force" than the robot trying to dislodge them. And on top of that they have the forces being applied to them by the tower.
I don't think you'll see 469 budge.
[FTC]: High Score of the Year? Rick TYler FIRST Tech Challenge 9 19-02-2010 16:20
High Score at the CT Regional seg9585 Regional Competitions 34 19-03-2008 07:45
The 2007 High Score Thread Donut General Forum 95 03-04-2007 13:19
Archimedes wants the nation's high score! archiver 2001 8 24-06-2002 03:11
High score Dave Hurt Regional Competitions 3 08-04-2002 03:39
